help needed!! weird after 4 wheeldrive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by enjm10, Aug 3, 2011.
  1. Aug 3, 2011 at 8:38 PM
    enjm10
    enjm10 [OP] Well-Known Member
    Eric
    NM
    2020 White Double Cab
    5% Front strip and doors, 20% wrapped around the rest of the truck.
    Ok so I went trail riding through some rough/muddy terrain and disengaged four wheel drive soon after I didn't need it anymore. Drove back into town n came up to a stoplight perfectly fine. Parked truck at home then after eating got back in truck to notice the truck was driving really crazy. The steering wheel was wobbling really really bad and at a parked position I couldn't turn the wheel to the right only to where it was straight so I turned back around n tried driving home n its terribly bad the wobbling is so intense I couldn't go over 20. So I pulled over put truck in 4lo n the light kept blinking n beeping put it into 4hi n the light blinked then stopped n stayed lit. Put it back to 2 and it kinda clunked but it did it too when I disengaged after offroading. And as I suspected wheel is still terribly wobbly. Crawled under truck n saw Nothin wrong w driveshaft axles or any other components. Anybody know what's going on any help is greatly I mean greatly appreciated I need to know if I need to take truck to dealership for repairs while still under warranty if its a warranty matter n if they will honor it. Thanks for reading again any help or insight will be appreciated.
    Thanks
    Eric
  2. Aug 3, 2011 at 8:44 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Don't be accelerating or slowing, be coasting when disengaging and you won't get the clunk. As far as wobbly, mud probably fell off bottom of tire when parked but not the top making it unbalanced. And not being able to turn right is because there was a curb there!
  3. Aug 3, 2011 at 8:44 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Mud caked in the wheels ?
  4. Aug 3, 2011 at 8:44 PM
    baja820
    baja820 Well-Known Member
    pacific northwest mountains
    '11 SR5 Tacoma V6 6MT 4x4
    Kinda sounds like the front diff is messed up. My friend had a similar issue with his '94 Toyota 4wd truck.
  5. Aug 3, 2011 at 8:46 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    what??? how would that effect steering?
    check for mud like others said.
    check tie rod ends, ball joints, wheel bearings. i think the 4wd may be coincidence
  6. Aug 3, 2011 at 8:47 PM
    Yoytoda
    Roland
    completely stock
    take lots of pictures of the suspension and post them
    EDIT: also if you killed the alignment and your toe is way out it will fight you and tend to wander. but really wobbly and uncontrollable below 20mph sounds like something it loose.
  7. Aug 3, 2011 at 8:49 PM
    enjm10
    Eric
    NM
    No mud in the wheels at all, I was parked when trying to turn the wheel to the right n it wouldn't go past the straight position, all mud is gone from the tires and undercarriage area. The wobbling is really bad when I accelerate slowly from a stopped position while leaving my hands off the wheel it goes to the far left??
  8. Aug 3, 2011 at 8:50 PM
    Yoytoda
    Roland
    completely stock
    sounds like you jacked a tie rod or the rack
  9. Aug 3, 2011 at 8:50 PM
    OZ-T
    Peter North
    British Columbia
    Any chance the alignment tabs on the LCA's took a good hit ?
  10. Aug 3, 2011 at 8:53 PM
    Yoytoda
    Roland
    completely stock
    could be a bent spindle too. it may be binding to the right if the spindle is causing the weight of the truck to not be vertical. am i making sense?
  11. Aug 3, 2011 at 8:57 PM
    enjm10
    Eric
    NM
    No I was trying to b careful never heard anything clunk or seem to be hit on the underside
  12. Aug 3, 2011 at 8:59 PM
    Yoytoda
    Roland
    completely stock
    did you hit the front of the tire at all? maybe hit a rock extra hard?
    it just sounds like the whole suspension should be gone over
  13. Aug 3, 2011 at 9:24 PM
    baja820
    Hypotheticaly speaking, let's say the transfercase was stuck in 4wd and the front diff had a busted tooth on either the ring or the pinion would that cause the truck to wobble and act weird? (Not trying to be a smart ass. I genuinly would like to know.)
  14. Aug 3, 2011 at 9:28 PM
    Yoytoda
    Roland
    completely stock
    no
    it would lock up 100% or be very crunchy. wouldnt wobble or cause issues with steering... that sounds like suspension.
    tcase stuck and r&P bad would be 2 catastophic failures. very very rare to have both simultaneously.
  15. Aug 3, 2011 at 9:31 PM
    enjm10
    Eric
    NM
    Ill be sure to check everything over in the early Morning as its 1030 here n no garage ill take pics n try to post also. Keep the ideas coming so I know what else to check
  16. Aug 4, 2011 at 6:30 AM
    enjm10
    Eric
    NM
    Tacoma still don't turn right in a parked position can duly lock wheel to the left but just right before full lock steering "pops" the sway bar end links r touching the spindle at full lock and still can't get the truck to turn to the right in a parked position with the truck started. HELP!! this is my daily driver n I need to figure it out. Everything looks fine tho tie rod spindles.
  17. Aug 4, 2011 at 6:30 AM
    enjm10
    Eric
    NM
    Think it has anything to do with 4wd? Myb I could try n engage n disengage it again or will it just make it worse?
    Edit: passenger tire seems to shake but when taking my hands off the steering wheel it gives like a sudden death defying jerk where I think I might flip the truck even going under 30. The passenger wheel also started squeaking real bad I can't seem to find any problem or fucked up parts tho. Made sure my wheel was lugged down good and sure enough there r.
  18. Aug 4, 2011 at 7:00 AM
    enjm10
    Eric
    NM
    Could it be the bearing going out that's all I could seem to figure. And does Toyota honor bearing replacement on the warranty or do I gotta take to a mechanic?
  19. Aug 4, 2011 at 7:10 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Sounds like bearings to me... Jack it up and see if you can make the wheel wobble... Or if you hear a grind
  20. Aug 4, 2011 at 7:12 AM
    enjm10
    Eric
    NM
    Think a bearing could go bad just like that tho in one day. I haven't heard any other noise from it before t drove fine. But I can check. What causes the wheel to "death wobble" I mean shit man its pretty damn rough. My hands look like an old 82 Chevy where u have to go right and left to keep the truck straight but this has tension on it n its not hard to control but it sucks.
