Help - New Leak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by [eric], Sep 9, 2018.
  1. Sep 15, 2018 at 8:59 AM
    [eric]
    [eric] [OP] Well-Known Member
    Eric
    Bend, OR
    2005 Tacoma TRD OFF Road
    I did some quick googling last night and found the same thing. I think its called the Outer tie rod. Does this look right?
    $35.96
    Part Number:45046-09330
    Part:Outer Tie Rod
    https://trdshop.carlocktoyotaoftupe...g9qrBhUzgaC15irIukUyiFYy9W71tg4hoCC_kQAvD_BwE
    The stabilizer link bar prices seems a little high. Is it sold in pairs?
    $107.30
    Part Number:48830-AD020
    Part:Stabilizer Link
    https://trdshop.carlocktoyotaoftupelo.com/oem-parts/toyota-stabilizer-link-48830ad020/?c=bT0x
  2. Sep 15, 2018 at 1:45 PM
    [eric]
    Eric
    Bend, OR
    When installing the axle seal, how far was I supposed to press it in?
  3. Sep 15, 2018 at 1:48 PM
    CBenfell
    CBenfell I don’t know sh*t about f*ck
    Christian
    Western Washington
    21 DCSB TRD OR Midnight Metallic Black
    Crippling Debt
    Those indeed look like the correct parts. I am uncertain on the stabilizers being sold in pairs though. I would phone up a dealership and ask. I also know that for certain vehicles, they can be sold left/right specific.
    When installing the outter tie rod end, count the exact #of turns/threads to be sure you reinstall it in the exact same spot.
    [eric][QUOTED][OP] likes this.
  4. Sep 15, 2018 at 8:05 PM
    [eric]
    Eric
    Bend, OR
    Its still leaking. I think the seal might be in the wrong position.
  5. Sep 15, 2018 at 8:07 PM
    CBenfell
    Christian
    Western Washington
    Crippling Debt
    What did you use to install new seal? If any damage occurred it will still leak
  6. Sep 15, 2018 at 8:14 PM
    [eric]
    Eric
    Bend, OR
    I used one of the extension tubes to my shop vac. The wide end was used to press the axle seal in.
    b_r_o likes this.
  7. Sep 15, 2018 at 8:16 PM
    CBenfell
    Christian
    Western Washington
    Crippling Debt
    Did the seal fold over in any way? What does the leaking substance look/smell like? If you did the seal without damaging it upon installation, as well as insertion of the CV shaft, I’m not sure where the fluid could be coming from. Could it just be residual?
  8. Sep 15, 2018 at 8:21 PM
    [eric]
    Eric
    Bend, OR
    The seal did not fold at all. I don't think it was damaged at all. I was hoping it was residue too but after a test drive it was a slow drip. The leaking oil smells like gear oil.
  9. Sep 15, 2018 at 8:28 PM
    CBenfell
    Christian
    Western Washington
    Crippling Debt
    Did you check for any damage or debris in the mating surfaces? If the metal has even a small gouge or nick, oil can seep through. But if it was dripping I am not sure what it could be. I’m hoping someone else will chime in. I’m very sorry that it’s not fixed though.
    Have you checked for any tears in the CV boot itself? I’m just going down the list of possible causes.
  10. Sep 15, 2018 at 8:37 PM
    [eric]
    Eric
    Bend, OR
    I quickly checked and ran my fingers plus a rag along where the seal goes. It was dark and hard to see into it.
    The I did not see any holes or rips in the CV boot. I was worried about ripping it when getting the CV in and out. Thanks for your help.
  11. Sep 15, 2018 at 8:39 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    The axle seal has to be installed flush. Did you even install it the correct orientation ?
  12. Sep 15, 2018 at 8:41 PM
    man17TRDoffroad
    man17TRDoffroad Well-Known Member
    Manny
    Basecamp Mars
    21 Tacoma DCSB TRD Offroad Cement
    Badge blackouts, tailgate inserts
    how far in did u press the seal in? some seals want to bottom out, some only flush mount where is this fluid coming from exactly? outer edge of seal or where the axel goes through
  13. Sep 15, 2018 at 8:45 PM
    CBenfell
    Christian
    Western Washington
    Crippling Debt
    I did mine today and my seal bottomed out. Left about a 1/16” sticking out proud. Unless it was put in backwards or damaged somehow, I don’t understand how it could be dripping immediately afterwards.
    Does the inner shaft have any sort of seal that could be at play here? I didn’t pay that much attention when doing mine. I just tapped it in. I even nicked the top edge a little but it’s not leaking anything.
  14. Sep 15, 2018 at 8:49 PM
    anthony250f
    Anthony
    San Diego, CA
    Could have installed it backwards. I have done it
  15. Sep 15, 2018 at 8:50 PM
    #35
    [eric]
    Eric
    Bend, OR
    Flush? I inserted it a little bit more so it has a small lip. I thought I read on another thread to stick it in 1/8 inch. I had the side of the seal with the little skirt facing out.
  16. Sep 15, 2018 at 8:52 PM
    #36
    man17TRDoffroad
    Manny
    Basecamp Mars
    like @CBenfell said earlier any nicks or gouges in the mating surface will cause a leak and if the seal was damaged or not sitting properly will leak
  17. Sep 15, 2018 at 8:53 PM
    #37
    [eric]
    Eric
    Bend, OR
    I can't tell. But its all shares the same mating surface so it looks the same to me. Sorry.
  18. Sep 15, 2018 at 8:57 PM
    #38
    [eric]
    Eric
    Bend, OR
    Mine is a passenger side axle seal. Is that what you did too? I think the driver side might be different.
    I did not see any other seals.
  19. Sep 15, 2018 at 8:58 PM
    #39
    anthony250f
    Anthony
    San Diego, CA
    I had to do this like 4 times to get it to stop leaking.
    Flush for sure
  20. Sep 15, 2018 at 8:58 PM
    #40
    man17TRDoffroad
    Manny
    Basecamp Mars
    just curious? I've never seen anyone use a shopvac extension did it go in easy? i usually use a socket that matches the size of the seal and gently tap it in evenly with a hammer
