Help! Nittos T.G. 265/70/17 Rubbing!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JackedTaco, Apr 2, 2010.
  1. Apr 2, 2010 at 11:51 AM
    JackedTaco
    JackedTaco [OP] Well-Known Member
    Johnny
    USA, Earth...
    07 Access Cab TRD Off Road
    Weathertech Mats, Thule rack custom install on bed caps. Foglite anytime mod. K&N air filter. Rear leaf TSB. Tinted passenger windows. TRD CAt Back exhaust. Bilstein 5100 front shocks at 1.75".
    Hi guys, I have a 07 access cab offroad with the rear leaf TSB done.
    I just got my new wheels and tires, Nitto Terra Grappler 265/70/17 on XD Addicts 17x9 4.5 offset and -12 Backspace.
    The dealer mounted the front and when I turned my wheel the tire rubbed big time on the front part of the fender...
    I do plan to lift soon, I was going to go wth Billy 5100's set at 1.75 on stock springs.
    Will this fix the problem or do I need to look at another route. I have the wheels off and old ones on till I can put on correctly.
    Help! dying to get my new kicks on my truck!
    Thanks in advance!!!
  2. Apr 2, 2010 at 11:52 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    my 265/70/16's rub with 3'' lift soo i cut the fenders down a little.
  3. Apr 2, 2010 at 12:08 PM
    JackedTaco
    Johnny
    USA, Earth...
    ok, whats the best method to trim that front fender piece????
  4. Apr 2, 2010 at 12:11 PM
    kinkrider101
    santa barbara
    wheels and tires
    i used a razor blade and just trummed the plastic nub that sticks out.its wiers how i rub with stock tire size and 3'' lift, must be the spidertraxx.
  5. Apr 2, 2010 at 12:44 PM
    JackedTaco
    Johnny
    USA, Earth...
    Rubs on the fender flair on the inner most corner. I am sure i can trim it without anyone noticing unless you look for it.
  6. Apr 4, 2010 at 10:50 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    how is that rubbing?? :eek:
  7. Apr 5, 2010 at 3:34 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    it's the rim. u can put that tire on a stock sport rim and it will not rub.
  8. Apr 5, 2010 at 3:44 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Is it just rubbing on that little box tit thing that hangs down in the front of the tire that's part of the fender liner? If so, you can cut the seams of it then fold it up on itself and put a screw thru it with a clip on the top side of it so the fender liner is still structurally intact and it's out of the way of the tire. Mine rubbed there when going to 32's. My rims are 18x9.5 so I'm sure that helped it rub.
  9. Jan 3, 2011 at 1:26 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    a stock tire for are trucks is a 265/70/r16 once youve increased your rim to a 17 insted of having a 31.61 you have a 32.83 almost 33 inch tire on stock thats why just get a 2.5 in front spacers and larger leaf springs for the rear and youll clear it only cost 180 to purchase those
