Help oil light!
Discussion in '1st Gen. Tacomas (1995-2004)' started by fouillard13, Oct 26, 2013.
  1. Oct 26, 2013 at 12:52 PM
    fouillard13
    fouillard13 [OP] Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    I was driving down town and my oil light was flickering at a stop light. Now it obly comes on at idle. When I was turning the steering wheel at a stop the light would flicker . I run 5w30 and the oil is super clean and at proper level
  2. Oct 26, 2013 at 12:55 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Oil light or maintenance light? If oil is at proper level and it is the oil light. Sounds like pump malfunction or failure. Better shut it off and get a pressure reading quick just incase
  3. Oct 26, 2013 at 12:58 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Oil light. I turned it off ran into store got back in it now I'm idling in a Starbucks drive through and it hasn't came on once. Was it just a little fart in the system ?
  4. Oct 26, 2013 at 1:04 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    And they are out of breakfast sandwiches
  5. Oct 26, 2013 at 1:06 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Man that would freak me out. I'd get an oil pressure gauge on it asap just to be sure.
  6. Oct 26, 2013 at 1:20 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    I hr an hour drive home. Fuck it.
  7. Oct 26, 2013 at 1:43 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Still good and no light
  8. Oct 26, 2013 at 2:10 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Could be the sending unit going bad. Definitely get a gauge on it and confirm pressure at idle on a hot engine.
    When you cranked the wheel, the power steering pump loaded the engine and dropped the idle 50rpm or so.
    That light is designed to come on at somewhere between 3 and 7psi... and without testing there is no way to know exactly where in that range. When I added a gauge to my motorcycle, I still wanted to retain the light, so I built an adapter. I went through 4 or 5 sending units, all the same part number, until I found one that triggered above 5psi.
  9. Oct 27, 2013 at 11:16 AM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    im pretty positive i run wix and never fram
  10. Oct 27, 2013 at 11:50 AM
    Buy1Get1Freee
    Buy1Get1Freee HERP DERP
    PEI
    2001 Tacoma TRD
    Grey Wire Mod, Bilstein 5100s, Eibach Coils! 255/85/16 KM2. DDM HID 35W 6000K, Homemade Rear Bumper, Trail Gear Rock Sliders
  11. Oct 27, 2013 at 11:51 AM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    put about 200 miles on it yesterday. never came back on.
  12. Oct 27, 2013 at 11:56 AM
    Buy1Get1Freee
    PEI
    2001 Tacoma TRD
    Could be a system glitch...... I had the same thing on my 08 R8. Low oil pressure light came on, shut it down checked the levels (they were fine) started it back up and never seen it since. Scared the shit out of me though!
  13. Oct 27, 2013 at 11:59 AM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    ^ yup thats what im thinking.
  14. Oct 27, 2013 at 1:31 PM
    tacoma04
    tacoma04 Laissez les bons temps rouler
    Bruce
    Northern Louisiana
    2017 TRD OR DCSB BBP
    Where do you connect an oil pressure gauge on the 3.4 v6 engine? Not having a problem, but would be good to know.
  15. Oct 27, 2013 at 2:10 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    For troubleshooting, I'd replace the factory sending unit with the gauge's sending unit.
    For a permanent installation, you can use a brass "T" to make a manifold to mount both of the sending units, then plumb that to the pressure port.
    Just make sure that the brass "T" is grounded.
    Here's how I did the one on my bike. The large sending unit is for the gauge, the small one with the rubber cap is for the idiot light. I soldered a brass screw to the "T" and two nuts and lockwashers secure the ground wire (not yet connected in this picture)
    The braided stainless hose on the left connects the sending units to the pressure port. I've seen guys thread the "T" directly into the case, but I don't trust that much weight hanging on a 1/8" brass pipe nipple.
    The zip tie around the sending unit is only there to secure the bracket and sending unit while I snugged the hose clamps.
  16. Oct 27, 2013 at 6:28 PM
    tacoma04
    Bruce
    Northern Louisiana
    Thanks Rich. Would have never thought about the grounding of the brass T.
  17. Oct 27, 2013 at 6:30 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Turned out that I was grounding just fine through the stainless hose and fittings, but I ran the wire to be sure.
