HELP on deciding u joints
Discussion in '1st Gen. Tacomas (1995-2004)' started by ilove_taco_ma, Jun 22, 2011.
  1. Jun 22, 2011 at 9:23 PM
    ilove_taco_ma
    ilove_taco_ma [OP] Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    i've been looking to replaced my u joints. my u joints on my driveshaft are replaced once when i had bad vibes. instead of greasing the joints, i had it replaced with autozone duralasts u joints. the two joints at end doesn't have the greasing hole, but where the yokes are at, has the u joints lubeable. i've been looking at 4wp for the u joints. not sure which one to get for the ends.
    http://www.4wheelparts.com/Drivetra...&t_s=237&t_pt=3624&t_pl=102547&t_pn=D/S5-134X
    or this:
    http://www.4wheelparts.com/Drivetra...t_s=237&t_pt=3624&t_pl=102545&t_pn=D/S5-1201X
    right now, i need to grease my u joints except that the ends at the cb and rear axle i can't, due to that it can't be lube. got any suggestions?
  2. Jun 22, 2011 at 10:26 PM
    Scott78
    Scott78 Well-Known Member
    Scott
    Flagstaff, AZ
    '19 OR DCLB
    You're post confused the fuck out of me.
    If I were you I would call 4wheel parts and ask them. Looking at your links you posted I think the two options are different sizes. Your best bet is call and ask them or a part store.
    Good luck with your install
  3. Jun 22, 2011 at 10:43 PM
    ilove_taco_ma
    fresno, california
    95 tacoma 4wd LX
    sorry for the confusion, but what i'm trying to describe is that both of the u joints at the rear axle and by the carrier bearing are from autozone. they dont have the nut to grease them. so its starting to feel the vibes from the rear. well yes, i will call 4wp for more information.
  4. Jun 22, 2011 at 10:50 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Whatever U joints you go with just make sure you get greaseable joints & avoid ANY bearing that is a "perma-lube" or sealed, non serviceable... you'll only regret it later..;)
  5. Jun 24, 2011 at 1:11 AM
    Scott78
    Scott
    Flagstaff, AZ
    '19 OR DCLB
    x2, pumping some grease in a zerk it a lot easier and cheaper than replacing the damn thing all over again.
  6. Jun 24, 2011 at 10:19 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Amen to that....;)
  7. Jun 24, 2011 at 1:50 PM
    ilove_taco_ma
    fresno, california
    95 tacoma 4wd LX
    true! shouldn't thought of it yet before even thinking of replacing the u joints. didn't know why i even thought of replacing it. i shoulda grease them.
