Help on differential drop kit
Discussion in 'Street Trucks' started by GilbertBankston, Mar 6, 2012.
  1. Mar 6, 2012 at 12:19 PM
    GilbertBankston
    GilbertBankston [OP] Member
    Gilbert
    Louisiana
    2wd access cab sr5
    I have a 08 access cab I dropped the back 3" now I'm gonna use the differential drop kit i bought for the front now how do I do it an pics will help if u have any you alls help is much needed
  2. Mar 6, 2012 at 12:28 PM
    tbturner47
    tbturner47 Well-Known Member
    Travis
    Lenoir, NC
    '07 Indigo Ink Off Road
    Supercharger
  3. Mar 6, 2012 at 1:27 PM
    Manwithoutaplan
    ID
    he is going to drop his rear axle :rofl:
  4. Mar 6, 2012 at 1:31 PM
    GilbertBankston
    Gilbert
    Louisiana
    2wd access cab sr5
    Yea i have a 2wd.Well that sux the stupid site I got it from said it would wrk .is a balljoint flip mean the same i dnt know its my first time messing withis type of stuff..
    well how do I drop the front without cuttin the coils
  5. Mar 6, 2012 at 1:32 PM
    Manwithoutaplan
    ID
    what is the website??
  6. Mar 6, 2012 at 2:13 PM
    mjp2
    mjp2 Living vicariously though myself Moderator
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Yeah, you don't have a front differential so you don't have to worry about that.
    Lowering the suspension is what you're after, correct?
  7. Mar 6, 2012 at 2:14 PM
    GilbertBankston
    Gilbert
    Louisiana
    2wd access cab sr5
    Discountautoshocks.com
  8. Mar 6, 2012 at 2:16 PM
    GilbertBankston
    Gilbert
    Louisiana
    2wd access cab sr5
    Yes lowering the front already dropped the back 3"
  9. Mar 6, 2012 at 2:20 PM
    mjp2
    NJ
  10. Mar 6, 2012 at 4:24 PM
    GilbertBankston
    Gilbert
    Louisiana
    2wd access cab sr5
    Usually when u drop something u lower it smartass like I said I'm new to this dnt need ur immature comments
  11. Mar 6, 2012 at 7:17 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    you can go with the DJM 3" drop kit, Sittin Sic coils (changed the company name but old web link will redirect you - although coils are meant for a XR w/a 4.0L engine, you can still use them, but will only drop you 1.25" for the most) or find someone that can make you spindle spacers. With the 2nd gen tacos, you can't do the bj flip like on the 1st gens.
  12. Mar 8, 2012 at 6:09 PM
    2damax
    2damax Member
    paradise
    spank'n
    1.25 OR.... 1.75 in the front AND 2.25 in the rear with sittin sic kit ????
