Help, On vacation & truck won't start!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by crutch024, Sep 16, 2009.
  1. Sep 16, 2009 at 7:42 AM
    crutch024
    crutch024 [OP] Well-Known Member
    Scott
    Fairfield, Ohio (near Cincinnati)
    2014 Spruce Mica TRD Sport Doublecab
    Pop & Lock 8521; Extra Power Outlets in Center Console; G-Tek Fab Door Sill Protectors; Salex Organizers; NFAB Side Steps; Weather Tech Mats
    Good morning all, I could really use some help!
    I am on vacation 700 miles from home and my truck stopped.:mad:
    It started fine yesterday. I went to get some breakfast this morning and it worked fine. When we came out about 5-7 minutes later, it wouldn't start. When I insert the key and turn, the check engine light and ABS light flash very quickly, but the starter doesn't even click. The headlights do not work at all. The power doors sound like they work, but do not lock/unlock the doors. The power windows do not work. My ScanGuage turns on and all it says is "Connecting...".
    Any ideas abut what the problem could be? Is my battery going dead?
    Thanks for any and all help!!!!!
    Scott
  2. Sep 16, 2009 at 7:44 AM
    98tacoma27
    Ben
    Not Beech Creek
    Very possible the battery is dead. Can you get a jump to see if it will turn over?
  3. Sep 16, 2009 at 7:45 AM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    Battery or alternator would be my guess. hope its the battery....GOOD LUCK!!!!
  4. Sep 16, 2009 at 7:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    I would also suggest checking into the obvious: battery connections, look for blown fuse, etc.
  5. Sep 16, 2009 at 7:58 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    dead battery or bad connections on your posts. maybe a lil more info on your truck?
  6. Sep 16, 2009 at 8:02 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    What year is ur TAco ?
  7. Sep 16, 2009 at 8:03 AM
    crutch024
    Scott
    Thanks for all the fast replies... You guys are the best!
    Sorry..... Silver 2005 DC PreRunner with about 63,000 miles (bought it new).
    Scott
  8. Sep 16, 2009 at 8:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    Status? Have you found anything?
  9. Sep 16, 2009 at 8:07 AM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    Have had that happen. It's usually the battery. The Rav4 I had did that. Started and ran fine in the morning. Went to start it after work and the battery was dead. Jumped it, let it charge, and tried starting it again, no go. Took it to a Toyota service center and the battery had a dead cell. One dead cell in the battery was enough to render the battery useless.
  10. Sep 16, 2009 at 8:12 AM
    crutch024
    Scott
    Nothing yet.... I had to walk about a mile back to my hotel. I brought back the "Jump Starter" I borrowed before the trip. Unfortunately it also was dead. As soon as that is charged, I will walk back and try to jump it.
  11. Sep 16, 2009 at 8:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    :popcorn:
    When you do get it running, head to the first parts store and have the battery checked and alt tested.
  12. Sep 16, 2009 at 9:18 AM
    05TacomaTRDsport
    05TacomaTRDsport Member
    Derek
    Burlington On
    05 prerunner trd sport
    yeah def sounds like a dead battery or alternator
  13. Sep 16, 2009 at 9:45 AM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    yea my battery went out this past weekend, get yourself an optima with a 3 year warranty, with close to the same cca rating... and you will never regret it
    get the red top if u want starting power, yellow if you want accessory and starting power
  14. Sep 16, 2009 at 10:57 AM
    crutch024
    Scott
    I really appriciate all the advice, THANK YOU!!
    I got it jumped and it got me to an auto parts store. As soon as I shut it off, I could not get it started again....:mad:
    The guy at O'Reilly said that the battery was no good, I put in a new one and it started right up.
    Thanks again!
    Scott
  15. Sep 16, 2009 at 10:58 AM
    98tacoma27
    Ben
    Not Beech Creek
