Help picking a Tonneau cover...
Discussion in 'Tonneau Covers, Caps and Shells' started by legga400, Sep 24, 2012.
  1. Sep 24, 2012 at 10:00 AM
    legga400
    legga400 [OP] Active Member
    Massachusetts
    TRD Sport
    working on it...
    Does anyone have an opinion on the Access Roll up cover vs any of the Extang covers? I've narrowed it down to the following two but was hoping to ask current owners their opinions and find out if there are any red flags with each model...
    Access Roll Up Tonneau or the Extang Tuff Tonneau III
    thanks Guys! I realize there are many tonneau threads but none seemed to match my question specifically... Sorry for any duplicates...
    EDIT: Thanks Guys!! I went with the Access Roll Up. Hopefully I'll have it in time to install this weekend
  2. Sep 24, 2012 at 10:46 AM
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    BAKFLIP HD
  3. Sep 24, 2012 at 12:18 PM
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    well, not that you mentioned it, but I would not buy a fold-a-cover again. The hinges were not put on straight and it doesn't provide much water protection :(
    I like the idea of a solid cover
    however, the access cover is much simpler to roll us, but the extang has support bars that I would find benificial (lots of downforce on a cover)
  4. Sep 24, 2012 at 1:24 PM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    While both are vinyl covers, you are comparing two different styles.
    The Access being Velcro sided, the cross bars are attached to the vinyl, maintains use of your track system.
    The Tuff Tonno is a "ziplock" style attachment. The cross bars are removed and set aside. Track use may be limited.
    All things considered on a soft vinyl cover, the best choice out of any style or manufacturer is going to be the Access. My second choice would be the Extang Trifecta.
  5. Sep 24, 2012 at 1:50 PM
    jdm.obp
    jdm.obp Well-Known Member
    561, FL
    3" Pro Comp, 5% all around, Antenna X shorty, Debadged
    I have the TonnoPro tri fold, it's pretty sturdy and keeps water out fairly well. Looks good too for a $200 cover off ebay.
  6. Sep 24, 2012 at 4:40 PM
    yellowrubiu
    yellowrubiu Well-Known Member
    Empire State
    2012 DCSB 4x4 SR5
    Truxedo Lo-Pro-QT - I love mine and awesome price.
  7. Sep 24, 2012 at 4:49 PM
    kingston73
    kingston73 Well-Known Member
    eastern MA
    09 SR5 4.0L 4x4
    To answer your original question, I've had 2 access covers and they were both excellent.
  8. Sep 24, 2012 at 4:52 PM
    stanbp64
    stanbp64 Well-Known Member
    Greenville, SC
    2011PreRunner Sr5
    Access LE is a good cover!
  9. Sep 24, 2012 at 4:54 PM
    indyca
    indyca Member
    rob
    Richmond ON
    2012 Access cab SR5 4WD
    Brand new , just bought it today!
    I am now on my 4th Access Original cover on my 4th truck. (3 full size Fords and now on my new Tacoma)
    They have all been excellent.
  10. Sep 24, 2012 at 5:31 PM
    Jerryjc
    Jerryjc Well-Known Member
    New Jersey
    2012 TRD Off Road Barcelona Red 4x4 DCSB
    Tonno Pro soft Tri Fold bed cover
    Recently I installed a TonnoPro Tri Fold on my 2012 DCSB and I am very happy with the quality of the cover and the price.
  11. Sep 25, 2012 at 6:26 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Guess I'm one of the few with the Tuff Tonno. This is my second Extang tonneau, the first being the really cheap snap cover, but both have done quite well and I'm satisfied with the quality. Both covers aged well and I've never had a leak. That being said, a couple of detractors of the TuffTonno,,, the bows do hold the cover up, but it gives a bit of a bubble look to the back, it's not flat across the bed like the Access, and you need to deal with the bows when you roll up the cover; the J-hook seal does seal well, but it doesn't roll up as nicely as the velcro'd Access or the snap Extang that I had, ends up taking two people to roll it up tightly and get it secured since the J-hooks stiffen up the cover sides; the side rail tie-downs can still be used, but the cover rail hold downs restrict the movement of the tie downs to just one of the three areas that the two cover rail hold downs mark off.
    Overall I am happy with the Extang TuffTonno as it was quite a bit cheaper then the Access, but I think overall the Access would be my choice if I wanted a rollup cover and cost wasn't a big consideration.
  12. Sep 25, 2012 at 6:56 AM
    rhmeyer50
    rhmeyer50 Member
    Rob
    Got an Access cover on a 2000 Ranger used, kept the truck until 2010 and about 125K. The cover was a bit faded but did it's job.
    Best,
    Rob
