HELP! plastic cap stuck in Transfer Case
Discussion in 'Technical Chat' started by jeratbp, Jun 2, 2012.
  1. Jun 2, 2012 at 8:09 AM
    jeratbp
    jeratbp [OP] Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
  2. Jun 2, 2012 at 8:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Did you try to drain the fluid to get it out?
  3. Jun 2, 2012 at 8:17 AM
    jeratbp
    Jeremy
    Norfolk, VA
    Yes, the fluid has already been drained.
    I even added more fluid thinking I could flush it out.
    I'm certain the blue cap was on the bottle, forgot to take it off, put the bottle into the Fill hole then removed it. Blue cap is gone. I hope I'm not so tired that the blue cap wasn't on the bottle in the first place. I suspect it could/should slide down the inside of the case to the bottom, where I could see it.
  4. Jun 2, 2012 at 9:46 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    You've got two reasonable choices here.
    First, take the t-case off the truck, split it open and remove the FOD. Time, money, effort, etc, but also the surest way to know. You might be able to see it from the top cover of the transfer case, but I wouldn't put money on that.
    Second is to full your t-case to spec, and drive a few miles, chewing up the cap. Drain/fill/flush the case to get the bits of plastic out. This is not the preferred method. Thing is, those little bits could clog the oil pump in the transfer case and that's just a Bad Thing. :(
    Sucks, I know. Firsthand, I know.
  5. Jun 2, 2012 at 10:04 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I would be doubley sure that the cap was in there by using an inspection camera, like a snake camera, plumbers use to look inside drains if you have access to one.
    If not, get ready to tear down your t-case
  6. Jun 2, 2012 at 7:42 PM
    aptech
    aptech Jetfixer
    houston
    10 dc offroad
    toy teccoil overs 2.5 lift.600lb springs, allpro expedition leaf pack. cbi hybrid bumper, cbi slider,cbi rear bumper swing arm, roof rack ghostflames, sport hood, tsb steering, trd cai, red map lights, derp works custom platform for bed. backup cam any time mod, fog light any time mod. bed light mod. 400watt inverter mod. 2857516 dura tracs. beach sand intsall and a lot more shite
    before tear down walk away for twenty min or so then go back and search the whole area for the cap. it may not have been on in the first place :pray:.try visual confirmation for where the cap is first. my 2.
  7. Jun 3, 2012 at 5:19 AM
    jeratbp
    Jeremy
    Norfolk, VA
    I did fish a plastic tube down inside the case and didn't notice any obstructions.
    So I went with the idea that:
    1. The cap is not stuck inside the case
    2. If it is.... too late.
    I refilled the case with oil, and started the truck. No odd sounds from the case. Since it is plastic, if it is in there, hopefully it won't hurt anything. Next weekend I will redrain the oil again, thinking by then it should either be chewed up or have fallen to the bottom.
    For future reference though, here is what the inside of the case looks like as posted on the Rock Solid Toys forum:
    '05+ Tacoma Transfer Case
