help please, 2013 w/ 3" giving warning tone
Discussion in 'Technical Chat' started by Dark Knight, Jan 2, 2013.
  1. Jan 2, 2013 at 9:04 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  2. Jan 2, 2013 at 9:15 PM
    mclovin
    mclovin chicka chicka, yeah!
    Biloxi
    16 TRD OR DC Barcelona Red
    Prev, 04 Xtra Cab Prerunner, 12 SR5 4x4 AC
    this is awesome. finally an explanation to the high pitch whine.
  3. Jan 3, 2013 at 5:52 AM
    Dark Knight
    Dark Knight [OP] Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Yes. We are working in collaboration with as many resources as possible.
  4. Jan 3, 2013 at 7:28 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Anyone have a 2009+ service manual? All I have is a 2005-2008.
    Is there a point where the VSC and buzzer works properly: beeps loudly/normally, brakes, etc.?
  5. Jan 3, 2013 at 9:18 AM
    OZ-T
    Peter North
    British Columbia
    I'm interested in what they say , please keep us informed of any discoveries
  6. Jan 3, 2013 at 9:25 AM
    OZ-T
    Peter North
    British Columbia
    I do
    The VSC buzzer / beeper goes off when VSC / traction control engages
  7. Jan 3, 2013 at 9:31 AM
    GP3
    California
    4X4 TRD Off Road
    Ok, so it works properly at times, but does this weird phenomenon every so often.
    What you said earlier about being at the threshold seems to be the only decent explanation so far... Because all I've seen in my 2005-2008 manual points to a master cylinder solenoid problem. But, that doesn't make too much sense if the system works properly at times.
    BTW, see if your 2009+ manual says anything similar. I found it in the "BRAKE CONTROL – VEHICLE STABILITY CONTROL SYSTEM; BC–115; PROBLEM SYMPTOMS TABLE" section.
  8. Jan 3, 2013 at 9:47 AM
    OZ-T
    Peter North
    British Columbia
    There is nothing too exciting
    " When VSC is activated :
    ~ the slip indicator flashes and a warning buzzer sounds "
  9. Jan 3, 2013 at 10:03 AM
    GP3
    California
    4X4 TRD Off Road
    I don't know what good it will do, though the systems should be very close if not exactly the same, but here is the 2005-2008 problems symptoms table.
  10. Jan 3, 2013 at 10:05 AM
    OZ-T
    Peter North
    British Columbia
    Hang on , I realize now you meant the FSM , I don't have that unfortunately
  11. Jan 3, 2013 at 10:16 AM
    GP3
    California
    4X4 TRD Off Road
    A bit more info that may or may not help:
    Judging by that description, the slip light and buzzer should activate when VSC activates.
  12. Jan 3, 2013 at 10:18 AM
    OZ-T
    Peter North
    British Columbia
    Yes , they do
  13. Jan 3, 2013 at 10:19 AM
    GP3
    California
    4X4 TRD Off Road
    But when you guys experience the odd noise, they don't. Which sounds like a problem, except no lights come on to indicate a problem with the system.
    Weird.
  14. Jan 3, 2013 at 10:24 AM
    OZ-T
    Peter North
    British Columbia
    Correct , there is only a very faint tone
    The duration of the tone also varies , and is relative to how long you are in a condition that would approach the VSC threshold
    For example , I may get a quick pulse of noise if I hit a bump while cornering , while driving through a longer , tight cambered turn the tone may stay audible for the entire corner , and stays on until a second or two after straightening out
  15. Jan 3, 2013 at 10:28 AM
    #35
    Large
    Large Red
    Have either of you tried turning off the VSC system and replicating the beep? That would eliminate any variables or am I missing something else?
  16. Jan 3, 2013 at 10:29 AM
    #36
    OZ-T
    Peter North
    British Columbia
  17. Jan 3, 2013 at 10:31 AM
    #37
    Large
    Large Red
    :facepalm: Well I derped.
  18. Jan 3, 2013 at 10:35 AM
    #38
    OZ-T
    Peter North
    British Columbia
    NP
  19. Jan 3, 2013 at 10:37 AM
    #39
    Dark Knight
    Jeff
    NC/SC
    Plus the VSC turns back on at automatically above 30/40 mph.
  20. Jan 3, 2013 at 10:42 AM
    #40
    OZ-T
    Peter North
    British Columbia
    Not if you hold the button for 5 seconds
    If you just push the button it comes back on at 35mph
