help rims
Discussion in 'Wheels & Tires' started by brutalguyracing, Dec 26, 2009.
  1. Dec 26, 2009 at 6:25 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    i just bought these moto metal wheels and now they are saying they will not gaurentee that they will fit a tacoma???
    does anyone have these
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=190357184784&viewitem=&sspagename=STRK%3AMEWNX%3AIT
    here is the disclaimer
    I need you to read this disclaimer and let me know you
    understand before I can ship the rims and fill your order....
    Most Toyota's have larger break calipers or hubs that prevent
    most aftermarket rims from fitting properly. I suggest that you
    test fit these rims locally before making a purchase or having me
    ship the rims.
    I cannot guaranty that these wheels will fit on any Year, Make or
    Model Toyota Truck. This disclaimer is based on past
    experiences with Toyota Trucks and I am sorry for any
    inconvenience this may cause.
    Moto Metal 951 Black Finish
    16x8
    Limited Stock, Going FAST!!!
    6 on 5.5 Bolt Pattern
    Backspace 4.50 in.
    Max Load = 2200lbs
    Finish = Black
    Hubcentric = No
    Offset = 0 mm
    -12 mm offset and 4.53 inch backspace
  2. Dec 26, 2009 at 6:31 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    if they r for chevy,ide say no cause the center hole is smaller i believe on a chevy thus they wont fit.not a 100% on that though.
  3. Dec 26, 2009 at 7:25 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    this is the specs
    16x8
    Backspace 4.50 in.
    Max Load = 2200lbs
    Finish = Black
    Hubcentric = No
    Offset = 0 mm
    r they no good for a 09 tacoma????
  4. Dec 26, 2009 at 11:19 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    since they are not hubcentric, the center bore should be fine...
    since the newer tacoma has a bigger diameter size caliper, many 16s cant clear the inner diameter of the wheel, so the seller just won't be able to guarantee fitment...
  5. Dec 27, 2009 at 7:30 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    but my truck came with 16's...........
  6. Dec 27, 2009 at 8:59 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    then you should be ok, but the seller likely still will not guarantee any fitment...
    if you have a 4wheelparts in your area, see if they will do a test fit for you... just don't tell them you are not buying from them...
  7. Dec 27, 2009 at 9:13 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    U need to find out the size of the hub bore!
  8. Dec 27, 2009 at 9:27 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    yes,i think chevy is smaller as stated before.
  9. Dec 27, 2009 at 9:36 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    ya know, i just went and clicked on the link the OP posted, and since the seller lists these as Chevy wheels, then that explains why they wont guarantee fitment...
    save yourself the trouble and shop elsewhere as the hub wont work out...
  10. Dec 27, 2009 at 9:49 AM
    mike07yota
    mike07yota Active Member
    bay area
    07 dbl cab. white
    885's, 5100's, moto metal 951's black with 285's and tinted windows
    I kno this is my first post but YES they do fit. Moto metals only come in a 108 center bore (ours is a 106 if i remember right) and you have the right size and backspace. just make sure you get new lugs because the stock ones wont fit if im not mistaken. Just an FYI tho you can get them for around the same price from 4wheelparts. also do a search and you will see lots of guy have the 16x8 on there tacos.
  11. Dec 27, 2009 at 10:34 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    ok see here is the problem i have already paid for these....
    will spidertrax spacers cure any of these fitment issues or what?????????????
  12. Dec 27, 2009 at 10:41 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    before you drop anymore money, hold off on the wheel spacers...
    i was thinking the same as mike07yota but considering the info you posted above lists two different backspaces on the same item description, i already feel wary about the seller...
    wait until the wheels come in, do a test fit, and if all works out, then cool...
    if not, then deal with it from there...
    also, if ever in doubt, ask first before you buy
  13. Dec 27, 2009 at 10:54 AM
    mike07yota
    bay area
    07 dbl cab. white
    no wheel spacers are needed and a 265 75 will fit stock ucas without a lift no problem and you will be able to run a 285 with a lift and some minor trimming. hope that helps you out.
  14. Dec 27, 2009 at 11:18 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    ok here is the part # the company listed the item as moto metal 951 w/pm09516860300
    and this # is the only one moto metal lists for a 16+8
    this should not have to be so hard
    6+139.7
    0 offset
    4.5 back spacing
    hubcentric --no
    oh and i do have 2.5" lift front 2" rear aal and im putting 285/75/16 on these....
  15. Dec 27, 2009 at 11:34 AM
    mike07yota
    bay area
    07 dbl cab. white
    thats them. Yes those are the only ones they offer :thumbsup:
    And i have the same wheels sitting in my house waiting for other suspension parts before they go on. :wink:
  16. Dec 27, 2009 at 11:44 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    ok so i can have them shipped and relax...... thanks....
    that should have never of been this diffucult......people in this world over engineer everything.......
    now i can crack this cold beer open and buy my tires
  17. Dec 27, 2009 at 11:50 AM
    mike07yota
    bay area
    07 dbl cab. white
    No worries. I over thought way too much as well and did wayyyyyy to much searching before i got my 951's. Before i ordered mine I just did a search on this site and google and found out that lots of people have them in a 16x8. They look better in person than in pics. :cheers: to a cold one. Glad i could help.
  18. Dec 27, 2009 at 12:16 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    your the best now if my giants were doing better in could relax more
    where DID my New York GIANTS GO?????????
  19. Jan 5, 2010 at 8:24 PM
    Lizard1080
    Lizard1080 Well-Known Member
    Chase
    Georgia
    07 5lug SR5
    Readylift SST 5 lug, T-Rex Eyelids, Alpine CDA-105, 12" Alpine Type-R, Kenwood 1000w amp
    i know very little about wheels but is a 16 x 9 that much different? and will it fit a 5 lug ok?
