Help! Rubbing compound mistake!!
Discussion in 'Detailing' started by KevinH, Jul 12, 2010.
  1. Jul 12, 2010 at 6:45 PM
    KevinH
    KevinH [OP] Member
    Tacoma
    I've got a 2010 Tacoma Access Cab in metallic gray magnetic. Tried to take care of some minor scratches with wax and polish. That didn't help so I moved up to Turtle Wax rubbing compound. That seemed to take the scratches out but unfortunately it removed the clear coat shine with it. Tried the recommended Turtle Wax Hard Shell wax afterwords but there is still a dull spot where the rubbing compound did its thing.
    What can I do to fix this situation? Clear coat spray, another wax and elbow grease? Take it to the pros?
    Clearly I'm a bit clueless. I know it would have been much better to try this out on an out of the way spot before trying it on the 8-10 obvious places. Though I'd used rubbing compound a few years ago without any trouble.
    Please help me rectify things. Any and all suggestions are appreciated!!
  2. Jul 12, 2010 at 7:21 PM
    ScottyB
    ScottyB Well-Known Member
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    With rubbing compound you basically sanded your paint. You are going to need to go to a finer compound/polishing compound/very fine wet sand and then buff the hell out of it after that to get back your shiney.
  3. Jul 12, 2010 at 7:24 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
  4. Jul 13, 2010 at 2:52 AM
    KevinH
    KevinH [OP] Member
    Tacoma
    Thanks guys! I'm feeling better that I didn't do some major damage. Guess my buffing muscles are going to get a workout.
  5. Jul 13, 2010 at 7:07 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Where are you located? I can take that out for you n/c if you are local.
  6. Jul 27, 2010 at 8:45 AM
    LFH
    LFH Active Member
    Spring, Texas
    2001 Tacoma 4x4
    I haven't a clue, so will say none.
    Look for white polishing compound instead of rubbing compound
  7. Aug 20, 2010 at 5:53 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    So it sounds like this is a good thread to ask another question without starting another one. I was off roading and scratched up my truck. I used the same rubbing compound you did and it didn't do the job of removing the scratches but also didn't take the clear coat off. So am I not rubbing hard enough or what?
  8. Aug 20, 2010 at 7:54 PM
    Gooch
    Orange County CA
    ^Don't use rubbing compound.
  9. Aug 21, 2010 at 10:30 AM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    what should i do?
  10. Aug 21, 2010 at 1:41 PM
    Gooch
    Orange County CA
    Use a high-quality microabrasive polish like one of CSI's...or Meguiar's M105/M205.
