*help* Starting problems with my 04
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomarotto, Dec 9, 2010.
  1. Dec 9, 2010 at 12:38 PM
    tacomarotto
    tacomarotto [OP] "Change is inevitable, but growth is optional."
    Jon
    Jacksonville
    Audi S3
    Alrighty so my 04 will rarely start on the first key turn. in an event when my truck will NOT start:
    On the first turn it will usually just click. i will hear the starter click.
    the second turn of the key it may just click again.
    on the third turn it may hesitate to start and will perform a half ass turn over.
    on the fourth turn it usually starts.
    SOMETIMES it will start on the first try.
    It does this issue te most when it is really cold outside OR if i just went offroading and there is a little bit of dirt or mud in he engine. I DO NO GO MUD BOGGING. it starts the best when it is warm outside or my truck engine is already warmed up
    if i turn the key slowly it will have no hope of starting at all usually.
    i have to turn it pretty quick to get any sort of reaction
  2. Dec 9, 2010 at 12:40 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    How long since you replaced your battery? I've had cars in the past that have a hard time starting in the cold weather due to old battery but yours sounds more like a starter issue.
  3. Dec 9, 2010 at 12:43 PM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    the battery is relativley new... my lights work fine. so i dont think it is the battery
  4. Dec 9, 2010 at 12:48 PM
    TacoCat
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    I think your local parts store might be able to test your starter and alternator for you.
  5. Dec 9, 2010 at 12:50 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Sounds like the plunger in the starter is bad. You can rebuild it for $20 or so.
  6. Dec 9, 2010 at 12:55 PM
    Taco GTR
    Taco GTR Valdosta State University
    Orrin
    Shadydale/ Valdosta
    2003 Tacoma reg cab.
    Bone ass stock, 2nd air filter delete, JVC head unit, Alpine 600watt amp, JVC 1600 watt 12'' sub, Tractor Supply Company Toolbox, ALOT MORE TO COME.
    :confused: what is a plunger?
  7. Dec 9, 2010 at 6:15 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    I'm not trying to be crass, but do you park your truck with the wheels cranked to the left or right?
    I've noticed if I leave my truck parked with the wheels turned, I have to jiggle my steering wheel to get it to start. So now I rarely park without the wheels being straight. It seems like that by having the steering column in a bind, it affects a connection with the ignition...I don't know, weird.
    Just a thought...
  8. Dec 9, 2010 at 6:18 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    just go get the battery tested its the easiest thing to start with.
  9. Dec 9, 2010 at 8:13 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Battery tested 1st if its good then, alternator tested if its good then test the starter.
  10. Dec 9, 2010 at 9:58 PM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    naw i park with the wheels straight
    will do
    will do.
    thanks yall for the feed back
  11. Dec 9, 2010 at 9:59 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    One other thing:
    I believe I've read that the reliability of Toyota starters is really good. Before replacing, double-check that your contacts on the starter are not corroded or dull. I've heard that you can polish them up, put some dielectric on them, and be good to go.
  12. Dec 9, 2010 at 10:10 PM
    tacomarotto
    Jon
    Jacksonville
    Audi S3
    ill check the battery regardless if the issue is persistant but im almost 90% sure both my battery and starter and alternator are working fine.
    the battery is not even a year old.
    the alternator is a year old
    and the starter is the least likely of all because my truck is ticking when cranked
  13. Dec 9, 2010 at 10:20 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Fort Wayne Indiana
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    sounds like your battery, clicks always mean battery problem
  14. Dec 10, 2010 at 6:50 AM
    thombiz
    thombiz Active Member
    Corpus Christi
    01 Prerunner & '02 Tundra
    Ok, my understanding of the starter is that because it has such a large current draw when in starting mode that a normal switch (or solenoid) would easily burn out after a few uses so, they put in a heavy duty switch (solenoid). Even this heavy duty switch will have the internal contacts breakdown after years of service. The copper contacts becomes pitted and burnt due to the amount of electricity flowing thru them. When this pitted, the electricity has a hard time finding a path to travel thru consequently, the contact is made but no juice flows. This contact is the clicking sound you hear. The contacts are joining (the click) but they are too corroded to allow the electricity to get to the starter motor. Solution...take the solenoid (switch) apart and check the internal contacts. Clean contacts if appropriate, replace if too badly damaged. Re-install and test.
    Nonetheless.... check the battery first. Sometimes the battery and the cable connectors allows enough juice thru to light up the headlights, etc. just fine, but won't allow enough juice thru to make the starter work. Sometimes it's the battery, sometimes it's corrosion between the battery cables and battery.
  15. Dec 13, 2010 at 4:58 PM
    98Tacoma
    98Tacoma Well-Known Member
    adam
    V.A.
    1998 V6 xtracab
    k&N intake, 40 flowmaster turndown, westin brushguard,10 inch JL sub, alpine cd player.painted black tool box. bilstein 5100s 3inch Ebiach springs all around and toytec aal. mickey thompson beadlocks. and 33inch goodyear duratracs
    my truck has been doing the exact same thing it will sometime click a few times. almost crank and then hearing a loud screaching sound then it will sart the next time. ive check my battery and it seems to be fine. i believe it is the starter
