No longer stuck in Riverside. Ratchet strap saves the day despite better judgement.
Discussion in 'Off-Roading & Trails' started by Ambiguouse, Apr 14, 2019.
  1. Apr 14, 2019 at 6:31 PM
    Ambiguouse
    Ambiguouse [OP] do you even taco
    Steven
    Riverside, CA
    2015 Tacoma PreRunner Double cab
    -coil spring double wishbone front suspension - rear leaf spring suspension with staggered gas shock absorbers - 16" styld steel wheels BFG tires - engine skid plate - off road tuned suspension with bilstein shocks - 20% front windows tint - limo tint back door widows
    im legit stuck on this trial back tires are completely sunk in where I can’t move forward not back no matter how much gas I give it. Didn’t think that trial was going to sink me in since I’ve hit it a lot of times before. I don’t have any straps with me. Help anyone
    wilcam47 likes this.
  2. Apr 14, 2019 at 6:32 PM
    Dan 77
    Dan 77 I leave my bikes outside
    Dan
    San Antonio
    06 DCSB TRD Sport 4X4
    Kings and TC UCAS 01 DCSB 4X4 Totaled All-Pro bumper, mile marker winch
    Bump.... good luck op
    wilcam47 and Beretta4x4 like this.
  3. Apr 14, 2019 at 6:33 PM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
  4. Apr 14, 2019 at 6:33 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
  5. Apr 14, 2019 at 6:34 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    #lightbarsbeforelockers
    Start digging my friend. Doesn’t seem too bad of a spot
    1bad2k, Shellshock, CLC828 and 10 others like this.
  6. Apr 14, 2019 at 6:35 PM
    eon_blue
    eon_blue Most Improved Member
    Are you aired down? Air down to 12 psi and dig behind the tires with a shovel, maybe even put your floor mats or some wood planks behind the tires and you mostly likely will be able to reverse out.
    Dominic4Lo, Wixo, Twizted and 6 others like this.
  7. Apr 14, 2019 at 6:39 PM
    Ambiguouse
    Steven
    Riverside, CA
    What do you mean bump?
  8. Apr 14, 2019 at 6:39 PM
    StayinStock
    StayinStock Skittles; fruity yet taste like chicken
    Bob
    Missouri
    2018 OR
    Some
    Bump
    Beretta4x4 likes this.
  9. Apr 14, 2019 at 6:39 PM
    eon_blue
    He's "bumping" your thread so it stays at the top of the New Posts page, so people will see it
  10. Apr 14, 2019 at 6:40 PM
    Beretta4x4
    Josh
    Temple, TX
    Bumps thread to the top of active threads list so it's easier to find while simultaneously subscribing to updates
  11. Apr 14, 2019 at 6:40 PM
    Ambiguouse
    Steven
    Riverside, CA
    Bottom of my truck is literally almost touching the ground since I was giving it lots of gas I digged myself deeper in the hole
  12. Apr 14, 2019 at 6:41 PM
    Beretta4x4
    Josh
    Temple, TX
    Have you tried the suggestions above, yet?
  13. Apr 14, 2019 at 6:42 PM
    Ambiguouse
    Steven
    Riverside, CA
    My friends bringing me some wood planks right now and a shovel see if that works. Just getting worried I won’t be able to get out before dark and it gets completely dark where I’m at on these trails
  14. Apr 14, 2019 at 6:43 PM
    eon_blue
    From what I can tell there's a rock or ledge right in front of your front tires so you're going to have to try and reverse out of this if you want to get yourself unstuck, don't try going forward or you're going to dig deeper. Air down and dig room behind the tires so they can get traction in reverse.
    Gunshot-6A, MunchTIME, SR-71A and 4 others like this.
  15. Apr 14, 2019 at 6:43 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Do you have floor mats? Put them behind/under the rear tires. Do you have your stock jack/aftermarket jack? Maybe you can raise the truck up and put rocks in the ruts....doesn't look too bad. Have a bed mat? Put it under the wheel with power and back out.
  16. Apr 14, 2019 at 6:43 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    How is this even possible lol. Looks like hard pack dirt
  17. Apr 14, 2019 at 6:44 PM
    Ambiguouse
    Steven
    Riverside, CA
    I’m not giving it anymore gas forward I’m way to sunked in right now. Yes there’s a big rock where my back tires are stuck
  18. Apr 14, 2019 at 6:45 PM
    tcjacado
    tcjacado Well-Known Member
    You got that giant light bar and I hope you have a flashlight. Are you aired down..... let air out of the tires.
  19. Apr 14, 2019 at 6:45 PM
    anthony250f
    Anthony
    San Diego, CA
  20. Apr 14, 2019 at 6:45 PM
    Ambiguouse
    Steven
    Riverside, CA
    I’ll take a better picture in a bit I left my truck back on the trials i came get some stuff to help me out
