HELP! Stutter/Jerk when stopping.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Colorado Sven, Jun 28, 2012.
  1. Jun 28, 2012 at 9:34 PM
    Colorado Sven
    Colorado Sven [OP] New Member
    Stephen
    Colorado
    2003 SR5 TRD
    I recently bought a 2003 Tacoma with 200,000 miles. I was told by the dealer (Not a Toyota dealer) that it had nothing wrong with it other than a few cosmetic issues.
    However, I have noticed recently that right before coming to a full stop, there is a slight stutter/jerking feeling.
    Not sure if that is just the way it is with Tacomas, or if something is going out. Could it be something in the transmission, a transfer case, the brakes, anything? Please help! I have no idea what it is, or how serious it could be.
    Thanks!!
  2. Jun 29, 2012 at 12:07 AM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Is the warranty up? Even used cars usually have warranties for 30 days or so, I'd let their dime fix it.
  3. Jun 29, 2012 at 12:08 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Tighten up the alignment cam bolts
    Brie likes this.
  4. Jun 29, 2012 at 7:37 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Not sure from your description, but assume that you are not talking about and engine stumble, but rather the whole truck.
    Perhaps a better description of what is going on will help, as many are glad to help diagnose. My first thought was warped rotors. As you are coming to a stop is the problem continuous? A warped rotor will cause the pads to grab and then be fine in an alternating pattern. Grab, grab, grab.... Sometimes with a glaze brake problem you can get a groan/vibration when coming to a stop.
    Does it only happen when you are under a certain speed slowing down or more noticable when you are actually about to come to a stop?
    What happens if you let off the brake while it is having the problem? Does it stop doing it?
    Do you feel a pulse in the brake pedal?
    Steering wheel vibrate or shake side to side?
    Any pops, knocks or noises?
    Have you been under to see if you have a blown CV?
    Could be a lot of things. Let us know more and I'm sure posters on here will help you figure it out.
  5. Jun 29, 2012 at 10:17 AM
    Hoyle
    Hoyle Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
  6. Jul 14, 2012 at 8:36 PM
    Colorado Sven
    Stephen
    Colorado
    2003 SR5 TRD
    It does it when coming to a full stop and as the truck settles. It sometimes also does it when I am coming out of a stop, and take my foot off of the brake pedal. After some experimenting, I have found out that when coming to a stop, if I put it in neutral (it's an automatic) it does not have the jerking/stuttering.
    Not sure if this is related, but sometimes there is a vibrating feeling coming from the brakes when stopping. (Could be the road)
    Does this sound like something serious, or just something on a high miles truck.
    If it is an axle wrap, is that something that should be fixed right away, or can it be lived with?
    Hoyle: It seem very similar to that discussion.
  7. Jul 14, 2012 at 10:17 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Axle wrap only occurs on take off, not braking. As for the jerk/knock on decel, i've felt it too. I just flushed my transmission with this procedure http://www.tacomaworld.com/forum/2nd-gen-tacomas/68462-diy-full-flush-automatic-transmission.html and i will see if it fixes it. Also just installed new brake discs, pads and lines, which may fix it as well.
    I would grease my driveshaft if i were you. always a good thing to do, and i'm not sure if the slip yokes could play a factor when coming to a stop but maybe?
    On a side not, i was read an issue of 4wd toyota owner, and they had a review of a land cruiser auto trans valve body modification/product, which they said cured a knock/clunk/jerk they had when coming to stop.... hmmm... have to find that article.
  8. Aug 8, 2012 at 2:50 PM
    Colorado Sven
    Stephen
    Colorado
    2003 SR5 TRD
    Ok, I have not tried anything yet, because I have been too busy :/
    But I found this on another forum, and it pretty much describes my problem exactly.
    "So I have had my Taco for almost 2 years now and love it, but the axle wrap drives me nuts. What I have is when I come to a hard stop at a red light, whenever i get green and release the brake I get a good thump thru the drivetrain. From what I found out on here is that is an axle wrap problem the taco's have. Will the dealer do anything or should I just get some sturdier leafs?"
    http://www.yotatech.com/f2/tacoma-axle-wrap-re-visit-64698/
    I am not sure if the thump is through the drivetrain or not.
    Any new ideas?
  9. Aug 8, 2012 at 5:08 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Its typical with these trucks. If you have a more progressive/ slow stop it wont happen. I have been told axel wrap and have been told it the trans shifting into 1st. Don't know what it is, just feather out the very last part of the braking right before you stop and it doesn't seem to happen.
  10. Aug 8, 2012 at 7:51 PM
    BamaToy1997
    Bill
    Navarre, FL
    Axle wrap actually occurs when coming to a stop. The axle "wraps" slightly or binds just as you are coming to a stop. Then you get the clunk feeling as you let off brake and accelerate and the axle "un-wraps" or releases.
