help! tacoma wont start!
Discussion in 'Technical Chat' started by speed, Oct 24, 2009.
  1. Oct 24, 2009 at 4:10 PM
    speed
    speed [OP] Member
    I was hooking up some exterior lights today and was using a test light to test power in the dash fuse box. I was testing the 7.5amp fuse that is listed as IGN and initially the test light lit up....then it sparked. Now i dont have any power across the 7.5 amp fuse at all.
    And because of this...my truck turns over but will not start. I have checked all the fuses in the dash box as well as in the engine fuse box....all are good.
    PLEASE HELP!!
  2. Oct 24, 2009 at 4:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!.
    There has to be a fuse you missed. Check the ALT fuse, and the EFI fuse.
  3. Oct 24, 2009 at 4:20 PM
    speed
    speed [OP] Member
    ill go check them again...i am asumming it will be something in the engine fuse box .....?
    btw it is a 1999 tacoma 4 x 4 v-6
  4. Oct 24, 2009 at 4:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  5. Oct 24, 2009 at 4:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Also...Being as there was a spark of some sort, check for burnt thru wires.
  6. Oct 24, 2009 at 4:22 PM
    speed
    speed [OP] Member
    i checked the back of the fuse block and no burnt wires.....
  7. Oct 24, 2009 at 4:29 PM
    speed
    speed [OP] Member
    ok rechecked the fuses and the 80A ALT fuse is blown.....how do i get it out?
  8. Oct 24, 2009 at 4:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What year, engine, and drive configuration is your truck?
  9. Oct 24, 2009 at 4:51 PM
    speed
    speed [OP] Member
    ok....got it out...what a joke...had to take whole fuse block apart to get to the two screws holding it in!!!
  10. Oct 24, 2009 at 4:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeppo! Good to hear you got it. :)
  11. Oct 24, 2009 at 4:52 PM
    speed
    speed [OP] Member
    what is the 80A ALT fuse for?
  12. Oct 24, 2009 at 4:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Pretty much for the whole truck. It prevents damage from happening to the Alternator, and the ECU, etc...
  13. Oct 24, 2009 at 4:55 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    glad you got it fixed...is there anything you dont know about these trucks chris?
  14. Oct 24, 2009 at 4:55 PM
    speed
    speed [OP] Member
    hmm are they expensive? 80a?? and what would have caused it (something that big) to blow?
  15. Oct 24, 2009 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Lots of things can blow it. Be glad you blew it and not the ECU.
  16. Oct 24, 2009 at 5:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL...I dont know stereo stuff, and AC's. :eek:
  17. Oct 24, 2009 at 5:04 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Dude, I honestly don't think so :laugh:
  18. Oct 25, 2009 at 12:55 PM
    speed
    speed [OP] Member
    i bought the new 80A fuse for $8 installed it and still wont start! i was like WTF????
    then i noticed very vaguely that the AM2 30A fuse is blown too! GOD!
    now i have to run out and get one of those too.
    apparently the 30A am2 fuse runs injectors and such
  19. Oct 25, 2009 at 1:30 PM
    speed
    speed [OP] Member
    OMG! it's ALIVE!!
    thanks for everyones help!!
  20. Oct 25, 2009 at 1:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, I forgot to mention if the ALT fuse blowes, the AM2 fuse is usually a gonner too. :eek: Glad you got it fixed. :)
