Help TPS for supercharged v6
Discussion in '1st Gen. Tacomas (1995-2004)' started by break8012, Jun 19, 2012.
  1. Jun 19, 2012 at 6:40 AM
    break8012
    break8012 [OP] New Member
    Supercharger
    Hello Everybody I have a supercharged 2003 tacoma. The Throttle positioning sensor needs replaced. I went and got the stock part but thar didnt work. Toyota is saying i need a whole new throttle body at 1500.00 because that part isnt available separately. TRD wont sell the stand alone TPS. Has anyone had this problem?
  2. Jun 19, 2012 at 7:03 AM
    ScienceofSpeed
    ScienceofSpeed Member
    FFEJ
    Mesa, Arizona
    01 double cab 4x4 trd limited
    grey wire mod, disable drl, diff breather relocation, transmission cooler, deckplate mod, powerslot rotors, hawk HPS brake pads, steel braided brake lines, NGK Iridium plugs & wires, TRD headers, snugtop camper, husky floormats, OME 881, OME HD leafs, OME nitro sport shocks, TRD supercharger, non-turbo supra injectors, Walbro 255 fuel pump, URD 2.2 S/C pulley, AEM fic, One off all stainless 2 1/2 inch custom exhaust
    Most auto makers wont sell them seperate because they calibrate them to the throttle body. I would look for a good used one from a wrecking yard, just make sure you measure the output voltage to the ecu of the old one so you can match it with the replacement. Welcome to TW by the way, great bunch of people and info on here!
  3. Jun 19, 2012 at 12:26 PM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I had this EXACT same problem on my '03 with a S/C. Had this awful stutter at around 60mph. Yes, it was the TPS and I had to replace the whole throttle body.
