HELP traction control problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mike schultz, Nov 13, 2011.
  1. Nov 13, 2011 at 2:04 PM
    mike schultz
    mike schultz [OP] Member
    mike
    Oregon
    09 4x4 taco 4" 33's
    4" lift, 33's
    I have an 09 tacoma with traction contol. Does anyone know how to permanatly turn this off? My truck is lifted 4" and any small curvey road sets this off. It is dangerious! I hate it and have a new born due in a couple months. Its just not safe. The computer thinks one wheel is slipping so it automaticly locks up the opposite wheel to adjust the slip.(thats not happening). I need a fix quick. I live in Oregon, lots of rain and curvey roads. Not to mention if there was ice on the road this thing is going to slide itself right off the road
  2. Nov 13, 2011 at 2:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    With the truck stationary , push and hold in the VSC ( car with squiggly lines ) button for about 5 seconds .
    This will greatly reduce the sensitivity but it still lurks in the background .
    To turn it off completely look into Crom's ABS / VSC bypass threads
  3. Nov 13, 2011 at 2:08 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    With a lift, you need your VSC and ABS recalibrated at the dealer so that this won't happen.
    If you read your manual, if you are at a complete stop, press and hold the traction control button for 5 sec to turn off the traction control and ALSD. The VSC will still lurk in the backgroud, but at a less sensitivity.
    With a quick search, here are some helpful threads:
    ATRAC/TRAC (VSC)/Auto LSD explained:
    http://www.tacomaworld.com/forum/te...uto-lsd-explained-easy-understand-i-hope.html
    How to deal with the VSC after lift:
    http://www.tacomaworld.com/forum/suspension/41215-lift-vsc-answer.html
    and another thread started my another member that expresses the same interest as you
    http://www.tacomaworld.com/forum/2n...rn-off-all-vehicle-assist-systems-please.html
  4. Nov 14, 2011 at 7:52 AM
    mike schultz
    mike
    Oregon
    09 4x4 taco 4" 33's
    4" lift, 33's
    thanks i found some good info on vsc issues. recalbrating dosen,t seem to work either. i dont think anyone has found a solid fix yet. thinkin about unpluging the wheel sencer. i know this will also diable abs but its got to be alot safer than getting pulled into oncomming trafic.
  5. Nov 14, 2011 at 8:42 AM
    Kurdain
    Kurdain Well-Known Member
    Portland, OR
    I have a 09 TRD and I tried this and it seemed to make no difference.
  6. Nov 14, 2011 at 8:58 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What kind of lift did you do to get to 4" ?
  7. Nov 14, 2011 at 9:02 AM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    had mine re calibrated at the dealer it works just like stock now, still there but not doing what yours is, i know what your talking about though right after my lift the thing would kick in all the time in corners kinda scary. now it fine though.
  8. Nov 14, 2011 at 9:34 AM
    OZ-T
    Peter North
    British Columbia
    Recalibrating helps some and not others
  9. Nov 14, 2011 at 8:39 PM
    JKD
    JKD Well-Known Member
    Since VSC is starting to be reported as the most lifesaving safety component to be installed on vehicles since the seatbelt, and you have a baby on the way, perhaps you ought to consider restoring the truck to stock ride height and making sure the VSC operates as it should.
    I'm thinking of it as, transport baby with 4" lift and the electronic safety mechanisms (VSC, ABS) disabled, or transport baby with stock height and all safety features enabled. Might not be ideal for your off road ability or appearance, but might be better for safety for your baby.
  10. Nov 15, 2011 at 12:39 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    THIS ^^^
  11. Nov 15, 2011 at 6:57 PM
    mike schultz
    mike
    Oregon
    09 4x4 taco 4" 33's
    4" lift, 33's
    Thanks to all for the advice. Its of to the dealership for recalabrating. Someone mentioned maybe i should return it to stock to safely transport my baby. I definatly would if i have exausted ALL options.. However this should not be the case since my lift is not extreme. Lots of 2nd gen tacos in my area have simalar lifts and are not skiding into oncomeing lanes. Besides I have you guys in my corner to help me resolve these issues..... Right??
  12. Nov 15, 2011 at 7:01 PM
    OZ-T
    Peter North
    British Columbia
    05-08 Tacomas don't have VSC , I don't think disabling the VSC in your truck makes it any less safe than an '08 .
  13. Nov 15, 2011 at 7:30 PM
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    TOYOTAS, TOYOTAS EVERYWHERE
    I hate to be a downer, but....... xN
    But if that isn't an option, re-calibrate, or maybe go with a less intense lift.
    btw, if you do go stock, I call dibs on your rims :D
  14. Nov 15, 2011 at 9:14 PM
    OZ-T
    Peter North
    British Columbia
  15. Nov 15, 2011 at 9:22 PM
    OZ-T
    Peter North
    British Columbia
    y must u do that today ?
    u no wut i ment
  16. Nov 15, 2011 at 9:26 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    I have a 3" Toytec with AAL and I have no issues...
  17. Nov 15, 2011 at 9:26 PM
    OZ-T
    Peter North
    British Columbia
    Doesn't happen to everybody
  18. Nov 15, 2011 at 9:27 PM
    OZ-T
    Peter North
    British Columbia
    K
  19. Nov 15, 2011 at 9:31 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    :popcorn:
    Fink
  20. Nov 15, 2011 at 11:50 PM
    OZ-T
    Peter North
    British Columbia
    While absolutely true , the steering angle is only one factor , there is also the yaw rate sensor(s) .
