HELP! Turn off Door Chirp - 2009 - 2011 Tacoma's - Can't Understand Instructions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tunngavik, Jun 26, 2012.
  1. Jun 26, 2012 at 6:33 PM
    Tunngavik
    Tunngavik [OP] Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    I'm wondering if I can get some help from those who have been able to turn off the beeping noise when using the key fob to unlock or lock the doors on the 2009-2011's.
    I know there have been several threads on this but for the life of me I cannot get the instructions to work nor am I certain that I even understand them.
    These are the most complete set of instructions I could find. Other people have said by following these instructions they got it to work.
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
    HINT:
    The driver side door is closed.
    The ignition switch is turned off.
    The key is removed from the ignition cylinder.
    A transmitter button is not pressed for 10 seconds after answer-back switching mode is started.
    The transmitter is operated but the second button pressed is different from the first.
    Answer-back starts.
    OK this is what I don't understand, in the first block of text the OP states to follow once set of steps and then after the HINT portion says the opposite. WTF? Am I reading this wrong? I tried the first set of steps several times but to no avail.
    Can anyone provide some useful advice? Thanks!
  2. Dec 22, 2012 at 10:05 PM
    huntingr
    huntingr Member
    California
    09 Prerunner SR5 TRD Double Cab
    I know this is an old post, but some clarification may help either you or someone else who reads this post. I added the parts in BOLD RED below:
    (a) Open the driver side door (KEEP THE DOOR OPEN) and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON (KEEP THE IGNITION TURNED ON).
    (c) After 10 seconds (WAIT FOR 10 SECONDS), the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice (PUSH THE UNLOCK BUTTON ON THE REMOTE TWICE WITHIN 10 SECONDS), the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
    DONE - TURN OFF THE IGNITION AND CLOSE THE DOOR.
    This worked for me the first time on my 2010 Tacoma Pre-Runner. No more chirp when locking and unlocking the doors via the remote control key fob.
    - Hope this helps!
    MANY Thanks to whoever the original poster of this mod was!!!!!
  3. Dec 22, 2012 at 11:41 PM
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    Whoa, thanks. Going to try this on my 09 tomorrow. Will post result.
  4. Dec 23, 2012 at 5:41 AM
    itsakeeper
    itsakeeper Well-Known Member
    nova scotia
    2012 SR5
    hmmm, same procedure for 2012 ???
  5. Dec 23, 2012 at 10:03 AM
    ASUAviator
    ASUAviator Well-Known Member
    Anchorage, AK
    Tacoma TRD Off Road
    13!?! lol how long does it take to get the codes?
  6. Dec 23, 2012 at 11:49 AM
    huntingr
    huntingr Member
    California
    No problem!
    I'm not sure if it will work on 2012. It would not hurt to try it though, good luck.
    You don't actually get "codes". It just turned off the chirp. I noticed it no longer chirped afterwards. Good luck.
    FYI - I did not write this mod or know any technical details of it, I just wanted to make some clarifications for how it worked for me. Hope it helps.
  7. Dec 24, 2012 at 9:18 AM
    itsakeeper
    nova scotia
    2012 SR5
    Nope, shucks:(
  8. Dec 24, 2012 at 3:11 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    why not just unplug the beeper??
  9. Dec 24, 2012 at 9:16 PM
    huntingr
    huntingr Member
    California
    From what i've read, it should also work on the 2012. Bummer that it did not work for you.
    I used this method (on my 2010) because I don't have to modify or unplug anything. This option is designed into the truck's computer system, so why not take advantage of it. I'm not sure about the 2012 though, but I've read that it should work. If not, unplugging the beeper may be a viable option, provided it can be located. :)
  10. Apr 15, 2013 at 6:41 PM
    mosier4x4
    mosier4x4 Member
    Elkview, WV
    '11 SR5
    tint, wheel spacers, kenwood head unit, JL Audio 6x9's
    worked perfect on '11 SR5. THANKS!!
  11. Apr 16, 2013 at 4:54 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It works on a 2012 also.
    At least it did on mine..
  12. Apr 16, 2013 at 6:34 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    1. lift hood
    2. push fob button
    3. listen for and find buzzer ... clue: it looks like this and is up by radiator, driver's side
    4. unplug buzzer
  13. Apr 16, 2013 at 7:23 PM
    jamsandwich
    jamsandwich Ski Bum
    Teton Village, Wyoming
    09 DCSB TRD OR 6spd
    lol nice find
  14. Jun 3, 2014 at 6:57 PM
    Quadsix
    Quadsix Well-Known Member
    Don
    Bonaire, Georgia/Palm Bay, Florida
    12 Quadcab TRD Sport Upgrade
    K&N Intake Filter, K&N Cabin Filter, Redline Hood Struts, Tailgate Mod, Wet Okole Seat Covers, WeatherTech rain visors/digital floor mats, 6K HID headlights, 4300 HID fog lights, Westin Bullbar, Westin side steps, Westin Bull Bar, Westin Quadrant LED Aux Lights, Bed mat, Rocky Mount Clutch SD Bike Mounts, LED Bed lights, Blue LED shift indicator
    Anyone know where the wires are for that buzzer at in the cab? I need to splice into them and connect them into the Viper 4105v module, instead of that factory horn, which is totally annoying.
