HELP! Vibrations????
Discussion in 'Suspension' started by Stolzz, Feb 27, 2009.
  1. Feb 27, 2009 at 8:03 AM
    Stolzz
    Stolzz [OP] New Member
    San Diego
    08 PreRunner V6
    6" ProComp
    I have an 08 Tacoma Prerunner. I installed a 6in Procomp lift yesterday and I have a vibration coming from the rear-end/drivetrain. Only when I accelerate from 10-20mph. I did install the drop down spacers for the drive train (the 3/4 and the 1inch). I read in the instructions about a new bracket for the transmission, I would have to purchase. I havn't alined it yet - but I don't feel the vibration in the sterring wheel.
    Has anyone else had this problem? How do I fix it? Or is this something I have to get used to? Has anyone had to use the extra tansmission bracket?
    Thanks for your help-
  2. Feb 27, 2009 at 8:56 AM
    muliefever
    muliefever Muliefever
    Tillamook, Oregon
    14' DCSB TRD
    5100's, 887', CB, 265's, FM Deltaflow
    Shims? Makes sense to me.. Check them out at toytec!
  3. Feb 27, 2009 at 8:58 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    ....and/or a one piece drive shaft (eliminates the carrier bearing)
  4. Feb 27, 2009 at 9:15 AM
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    I was thinking shims, too, but I'm not a 4x4 guru like chris4x4. Ask him.
  5. Feb 27, 2009 at 12:46 PM
    trailmaster308
    trailmaster308 Well-Known Member
    Louisiana
    PreRunner 3" Toytec Adj Coilovers 2" AAL
    He's got a prerunner. Cant make a one piece for those. :(
    Or I would have one.
  6. Feb 27, 2009 at 12:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You can, but it would be a custom build.
  7. Mar 1, 2009 at 6:29 PM
    Stolzz
    San Diego
    08 PreRunner V6
    6" ProComp
    Thanks for the help. I'm guessing the shims are for the rear axle?? This would rotate it up- Right? changing the angle back to normal. I know this sounds really stupid but thanks for the help.
  8. Mar 1, 2009 at 6:44 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Thats what we are here for. Lets us know how you made out.
  9. Mar 1, 2009 at 6:48 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    rear axle shims will probably be your best bet..................but you can always put some spacers/stack some washers on the carries bearing....that will drop the drive shaft a little and may eliminate some of the vibes.
  10. Mar 2, 2009 at 8:14 PM
    trailmaster308
    Louisiana
    Whoa just seeing your reply.
    Not to hijack the thread, but who could I get to make this? I called Tom Woods and they told me it couldn't be done. :mad:
  11. Mar 2, 2009 at 8:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  12. Mar 3, 2009 at 6:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Try what Will said first. Then, check your local phone book and look for a driveline shop. They should be able to make one for ya.
  13. Mar 3, 2009 at 6:56 AM
    trailmaster308
    Louisiana
    Ya already installed the kit from Toytec along with shims. I wonder if my shim angles might be too much. I got less vibration when I had just the CB drop.
