Help! Wheels rubbing caliper
Discussion in '1st Gen. Tacomas (1995-2004)' started by Twilson24, Dec 7, 2011.
  1. Dec 7, 2011 at 3:40 PM
    Twilson24
    Twilson24 [OP] Well-Known Member
    Thomas
    Lexington
    1996 Toyota Tacoma 4x4
    Ok so I called jegs and they told me exactly what wheels would fit my 1996 Toyota Tacoma and I tried to get them put on today and they rubbed the caliper when the wheel was put on the the hub. I need to know exactly what wheels will fit that are 15x7 6x5.5
    Thanks
  2. Dec 7, 2011 at 10:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Any stock tacoma alloys will mount without rubbing the stock calipers.
    btw: welcome to tw
  3. Dec 8, 2011 at 5:34 AM
    Twilson24
    Thomas
    Lexington
    But I dont want stock wheels. I want a black wheel of some type
  4. Dec 8, 2011 at 5:47 AM
    radcat692000
    radcat692000 Well-Known Member
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    whats the backspacing???
  5. Dec 8, 2011 at 5:49 AM
    radcat692000
    Rob
    Clayton N.C.
    95 tacoma 4x4 sr5
    none
    there was a write up, up here where someone simply grinded a small area away on the caliper and the wheel fit fine.. the area that was rubbing was just a small portion of the caliper.
  6. Dec 8, 2011 at 5:51 AM
    Twilson24
    Thomas
    Lexington
    The back spacing on the wheels I have that don't fit that rub are 4 and 1/4 but there are to deep and don't spin at all when I put them on
  7. Dec 8, 2011 at 6:06 AM
    shadow17
    shadow17 Well-Known Member
    panhandle 850
    03 Tacoma 4x4 SR5
    Thats why you dont trust what businesses say and you order through them, that way if they mess up the size and fitting, they can send them back at there expenses and not yours.
  8. Dec 8, 2011 at 6:29 PM
    Twilson24
    Thomas
    Lexington
    What is my best bet for me to get black 15x7 wheels for my truck?
  9. Dec 8, 2011 at 6:31 PM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    You might clear with a wheel spacer a tiny 1/4" if you really want to keep the wheels. I got a pair for sale brand new.
  10. Dec 8, 2011 at 6:33 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
  11. Dec 8, 2011 at 6:40 PM
    Twilson24
    Thomas
    Lexington
    I was told not to use spacers
  12. Dec 8, 2011 at 6:42 PM
    Twilson24
    Thomas
    Lexington
    That's what I have but a 15x7 but my problem is that I have to 15x7's because I just got new tires that are 15x7. But will the 15x7 tire fit on a 15x8 wheel?
  13. Dec 8, 2011 at 6:42 PM
    KPT
    09 Prerunner
    By?
  14. Dec 8, 2011 at 6:43 PM
    KPT
    09 Prerunner
    15x7 is not a tire size. What size tires did you get? It should say 31x10.5x15 or something like that on them.
  15. Dec 8, 2011 at 6:46 PM
    Twilson24
    Thomas
    Lexington
    My local tire shop and people who have dealt with spacers.
  16. Dec 8, 2011 at 6:47 PM
    KPT
    09 Prerunner
    Okay but there are probably a thousand people on this site running spacers.
  17. Dec 8, 2011 at 6:50 PM
    Twilson24
    Thomas
    Lexington
    I know it's not a tire size my tires are the stock size that come on a 1996 Tacoma so they are 265/75/R15's
  18. Dec 8, 2011 at 6:53 PM
    KPT
    09 Prerunner
    Yes those are good to go for 8" wide rims.
  19. Dec 8, 2011 at 6:57 PM
    Twilson24
    Thomas
    Lexington
    Would stock aluminum wheels painted black look good?
  20. Dec 8, 2011 at 8:45 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    You can grind down the caliper, which many guys have done or you can buy 1/4" wheel spacers from any auto part store and most tire stores. I've been running 1/4" across the desert for 3 years and I've never had a problem. They're very small and won't harm anything. However, your stud will be shortened but I use them without a problem.
    Mine look like this.
