Help will this wheel fit
Discussion in 'Wheels & Tires' started by aportis72, Jul 24, 2012.
  1. Jul 24, 2012 at 3:15 PM
    aportis72
    aportis72 [OP] Well-Known Member
    Austin
    Supercharger
    Truck is a 2012 Double cab TRD off road.
    Wheel I want is a
    BBS RW
    specs are
    Offset: 20mm
    Bolt Pattern: 6-139
    Rec. Tire Size: 285/55-18
  2. Jul 24, 2012 at 3:48 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    1. BBS RWs are +10 offset, not +20.
    2. Do you have a lift?
    3. Who even makes a 285/55/18?
    Edit: looks like I found the tirerack page you are referencing.
    http://www.tirerack.com/wheels/Whee...odel=Silverado+2wd&autoYear=1999&autoModClar=
    Those are the RWs that are designed for Chevys, known as the RW014. Their hub bore is too small for our trucks. For toyotas, we need the RW016 or RW018, which are +10 offset and 106+ hub bore.
    I'm not sure why tire rack recommended such a ridiculously rare tire size. With those wheels you can run 265/65 or possibly 285/60/18 on stock suspension. I run 275/65/18 with those and 1.75" lift, minor trimming.
  3. Jul 24, 2012 at 3:50 PM
    KPT
    09 Prerunner
    Also, you have excellent taste in wheels. :cool:
  4. Jul 24, 2012 at 4:05 PM
    aportis72
    Austin
    Supercharger
    That what the back spacing on tire rack say.
    I will be running a 270/75R18
    I have a 3 inch lift Fox coils up front with camburg upper control arms and fox factory in the rear
  5. Jul 24, 2012 at 4:24 PM
    KPT
    09 Prerunner
    275/70/18?
    And did you see my edit up top? Could you post a link to the tirerack page?
  6. Jul 24, 2012 at 4:47 PM
    aportis72
    Austin
    Supercharger
    tire will beLT275/70R18 125P E/10 (33X11.00R18) Toyo Open country MT
    Haha just saw your edit So those wont work. So is the only place you can get these TRD parts 4 u? just got off the phone with Vivid racing they are the best price will be ordering through them.
    Last thing Do i want RW016 or RW018 And what is the difference???
  7. Jul 24, 2012 at 5:13 PM
    KPT
    09 Prerunner
    I believe the only difference between the rw016 and rw018 is that the rw018 accepts tpms sensors. I know that my rw016s do not. I'd confirm that the offset of the 018 is +10 like my 016s are though, because if it's 20, you probably won't be anle to clear those 275s.
    Also I've heard a ton of horror stories about vivid racing, but that was back a couple of years ago when I was involved in the Subaru community.
  8. Jul 24, 2012 at 6:01 PM
    aportis72
    Austin
    Supercharger
    Okay thank you. I will be going with the RW018 To try and keep the TPMS. Vivid Said they can get them for $250 a wheel way better than TRD parts 4 u at 310. I'm also having them powder coated Gun metal gray before install :)
    I really wanted Volk Te37 but $950 a wheel for 18 inch is way to much. The one guy on here that does have them got 16 probably because of the price Like 300 cheaper per wheel, but $650 is till way to much.
    He ordered them through vivid
  9. Jul 25, 2012 at 10:01 AM
    aportis72
    Austin
    Supercharger
    Well Vivid said they can not get them as they are an OEm part and BBS will not sell the RW018 or the RW016 to them.... I don't know if I believe them so looks like TRDparts4U gets my business again.
  10. Jul 25, 2012 at 10:43 AM
    KPT
    09 Prerunner
    They are indeed an OEM part, they came on the 04 tundra limited. TRDparts4u is Toyota of Dallas fyi. So maybe you can call the dealer near you and avoid shipping charges?
    I got mine on craigslist, $500 total for all four including tires :eek:
  11. Jul 25, 2012 at 11:16 AM
    aportis72
    Austin
    Supercharger
    Ordered :)
