Help wiring 7" kragens - fuse keeps blowing
Discussion in 'Lighting' started by Infra, Apr 14, 2012.
  1. Apr 14, 2012 at 9:14 PM
    #41
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Jonah responded to the OP's question and you quoted him in your reply.
    It looked as if you were the OP responding.
  2. Apr 14, 2012 at 9:16 PM
    #42
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    ahh i guess thats a little misleading if you didnt see the difference in our usernames ,sigs ,avitars and location..
  3. Apr 15, 2012 at 9:10 AM
    #43
    Infra
    Infra [OP] Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    ok now I am blowing fuses at the inline fuse coming from the battery GRRRRRRRRRRRRRRRR
    I've moved my ground thinking I didnt have a good ground, didnt change anything.
  4. Apr 15, 2012 at 9:11 AM
    #44
    anthony250f
    Anthony
    San Diego, CA
    are you using the radio shack relay?
  5. Apr 15, 2012 at 9:17 AM
    #45
    Infra
    Az
    it is a 5 pin tyco electronics 12v 20/30a relay. I think I may head to pep boys and buy a new relay.
  6. Apr 15, 2012 at 9:29 AM
    #46
    anthony250f
    Anthony
    San Diego, CA
    i have the radio shack relay and it workes great
  7. Apr 15, 2012 at 10:15 AM
    #47
    Infra
    Az
    ok using a brand new 5 pin 12v 30a relay and when I test it with a multimeter I have power going to the relay, but no power coming from the relay at 86.
    I'm totally confused now because the 2 different wiring schematics posted have the power wire coming from the relay and the ground opposite
    This one says that 86 is power FROM relay to switch and that 85 is the ground
    This one says that 86 is the ground and that 85 is power FROM the relay to the switch
  8. Apr 15, 2012 at 10:27 AM
    #48
    anthony250f
    Anthony
    San Diego, CA
    i followed the second one exactly and had no problems, the relasy should tell you what number are what
  9. Apr 15, 2012 at 10:55 AM
    #49
    Rich91710
    Rich
    Los Angeles
    08 Base
    It doesn't matter.
    85 and 86 are the relay coil and they can go either way.
    The only thing that might make a difference is if there is a diode installed across 85 and 86 to shunt any back EMF to ground. In that case, connecting power to the "wrong" end of the diode will result in a direct short through the diode when the switch is turned on.
    In this installation, the banded end of the diode is connected to the source (in this case, the switch side of the relay) and the non-banded end goes to the grounded terminal on the relay.
  10. Apr 15, 2012 at 10:57 AM
    #50
    Rich91710
    Rich
    Los Angeles
    08 Base
    BTW: With the switch off, you should see NO power on 85 or 86 (regardless of how it is wired).
    The relay is not providing power to the switch... that is coming from your fuse block.
    The switch applies power to the relay via pin 85 or 86.
    That energizes the coil and pulls the contact in, which sends power from pin 30 out through pin 87.
    Here is what's happening inside the relay.
    You should have no more than 4 ground connections... one on the unswitched side of the relay coil (either 85 or 86), one on each of the fog lights, and one on the lighted switch.
    I suspect that you may have an issue with the switch wiring. The ground on the switch is not needed for normal operation... only to light the switch. As a test, lift the ground from the switch and try it.
    Use your meter to double check which terminals from the switch are the power source, switched out, and the ground for the indicator light.
    Normally, the center terminal is the power switched out, and the terminal on the "bottom" (when the rocker is off) is the hot, the 3rd is ground. The switch should be labeled, but a lot of the Chinese shit we've been getting for the last 10 years is not.
  11. Apr 15, 2012 at 11:07 AM
    #51
    Infra
    Az
    AAAAAAAAAAAAARRRRRRRRRRRRRRRRRGGGGGGGGGGGGGGGGG.....holy fuck I think I may have it wired up right now
  12. Apr 15, 2012 at 11:08 AM
    #52
    Infra
    Az
    My ground from the lights was not properly grounded to a "good" ground
  13. Apr 15, 2012 at 11:18 AM
    #53
    Infra
    Az
    thanks to everyone who spent their time trying to help me fix my wiring!!!!!!!!!!!!!!
  14. Apr 15, 2012 at 11:24 AM
    #54
    Rich91710
    Rich
    Los Angeles
    08 Base
    It's kinda tough with a 300 mile long screwdriver :D
  15. Apr 26, 2012 at 6:26 PM
    #55
    2010TRD
    2010TRD Well-Known Member
    Thomas
    Waldo, FL
    2010 MGM trd offroad DCSB
    Billistein 5100 front/rears, Toytec 2" AAL Custom grill, All Pro rear bumper, All Pro sliders, Anytime elocker/foglights, Rear diff vent relocated, W/O seat covers, weathertech mats/visors, nfab tire racK, cobra 75 stealth CB, Custom engine/trans skids 3/8", Hella and HID behind grill, LED bar backup light, LED pods under cab (rocklights)
    Subd........Im installing used HID lights, that came with a POS wiring harness........Dude had "speaker wire" for power leads to relays.....
    I have been scratching my head all day, about this wiring......I think all my issues/questions are answered in this thread......Gonna get back on the install tomorrow.........
    Rich.you seem like you know what your talking about.....I may have some questions for you......:)
  16. Apr 26, 2012 at 6:34 PM
    #56
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    9 times out of 10, thats the problem with wiring auxillary lights for a beginner.
  17. Apr 26, 2012 at 6:49 PM
    #57
    Rich91710
    Rich
    Los Angeles
    08 Base
    HIDs are a bit more complicated.
    Honestly, I would never buy a used HID set... just too many things that can get fucked up, including improper usage (flicking off and on destroys the burners).
    Me and HID go way back to before they were used for headlights:
  18. Apr 27, 2012 at 4:29 AM
    #58
    2010TRD
    Thomas
    Waldo, FL
    Well I actually bought the lightbar.........and got HID with it.
    atleast thats how I look at it......I payed for a bar, and got lights for free.....:)
    I bought it here (TW) from a 'mogace' He shipped them with little/no packing materials, so one of the lights was broken in transit....
    I figured buying from here would be better.....I guess I was wrong.......
    Like said before, the wiring harness was crap also.......
    I am very displeased with my recent purchase.........but am going to try and salvage atleast two of the four lights.
