Help with 4WD prob
Discussion in 'Suspension' started by alpine331, Apr 15, 2009.
  1. Apr 15, 2009 at 9:04 AM
    alpine331
    alpine331 [OP] New Member
    Banff, AB
    07 Tacoma DC TRD
    Hi all. I have a 2007 Tacoma DC Auto 4WD. I have a 3" Revtech lift, 33" BFG Allterrains on 16" alum rims. I had the rear leaf suspension TSB upgrade to the Blisten shocks done last year. My problem started a few months ago. During a bad snow storm I put my truck into 4WD and immediately noticed a strong pull to the right when I stepped on the accelerator. I had noticed this before and had attributed it the larger tires, but it had never been that strong. Then I came across a patch of snow/ice that only covered the right side of my lane. As soon as the right tire hit the snow (the left was on dry pavement) the truck swerved DRASTICALLY to the right. I almost lost control. And now it happens all the time. Every time the right tire touches snow/ice the truck swerves very hard to the right. I though it was a wheel alignment issue so I took it in for an alignment but it made no difference. And as soon as I take the truck out of 4WD the problem goes away. I called my local Toyota dealer and they told me because I have lifted my truck and put larger than stock tires on it that it would void any coverage under warranty and I would have to pay for them to have a look at it. I realise I could fight them on that issue but I was hoping someone might have heard of this or have an idea as to what it could be?
  2. Apr 15, 2009 at 9:07 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Welcome to TW.
    Magnusson-Moss Warranty Act
    Show this to them.
    Other than that I can't help you sorry and good luck. Keep us posted.
    I have virtually all the same mods as you and have never exprienced this.
  3. Apr 15, 2009 at 12:14 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    First off...
    You need to determine if both front wheels are moving/driving when in 4WD.
    If one side isn't driving - that could cause you to pull to one side. Amoung other reason, but that would be the first thing I'd check.
  4. Apr 15, 2009 at 4:22 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Sounds like the hub on the right side is not engaging. So you are only getting power to the left tire.
