Help with alignment specs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Infra, Mar 22, 2012.
  1. Mar 22, 2012 at 4:11 PM
    Infra
    Infra [OP] Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    2010 TRD OR Dbl cab with toytec ultimate lift set at 3" in front and dakar leaf packs in the rear. I have LR UCA's. I initially had an alignment like 3 days after putting the lift on, roughly about 1.5 years ago. I have not had pulling issues with the steering but have excessive outter tire wear. So decided to get an alignment, cost me $80. Seems to have a very slight pull to the left now. Are these aligment specs normal? They said they set the alignment to factory specs.
    Before measurements
    LF RF
    camber 0.0 camber 0.1
    caster 1.9 caster 1.9
    toe -0.12 toe 0.02
    LR RR
    camber -0.4 camber -0.4
    toe -0.06 toe 0.16
    After measurements
    LF RF
    camber 0.5 camber 0.5
    caster 1.8 caster 1.8
    toe 0.03 toe 0.03
    LR RR
    toe -0.04 toe 0.17
  2. Mar 22, 2012 at 4:12 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    .heres mine
    right
    -0.1 camber
    2.4 caster
    0.08 toe
    11.8 sai
    left
    0.1 camber
    2.1 caster
    0.06 toe
    15.7 sai
  3. Mar 22, 2012 at 5:01 PM
    tackytaco
    tackytaco Active Member
    N-Ville
    2012 DC TRD Off-Road 4x4 Debadged
    Just had mine done on the 14th, and my after's are below. No issues at all after the adjustments.
    LF ----------------RF
    .6 Camber---------.5 Camber
    1.3 Caster---------1.5 Caster
    .1 Toe-------------.07 Toe
    LR-----------------RR
    -.2 Camber--------/-.4 Camber
    .4 Toe------------/-.17 Toe
