Help with building a wire harness
Discussion in 'Lighting' started by STravis, Jul 9, 2015.
  1. Jul 9, 2015 at 8:44 PM
    STravis
    STravis [OP] Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Ok guys I am not all that great with electrical stuff but I take a lot of pride in things I do so I want this to be perfect. I am adding 3 pairs of led pods to my truck. 2 pairs will be in the bumper and one pair will be ditch lights. I want to set them all up on relays. I want to put each pair on their own switch but I also want a master switch to turn all of them off or on depending on the position of the individual switches. I have kind of sketched an idea of what I think I need. Let me know what you guys think.
    Also, what gauge wire should be used for the entire thing? I was thinking 16ga.
  2. Jul 9, 2015 at 8:47 PM
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
  3. Jul 9, 2015 at 8:49 PM
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    So you're wanting the master switch to be dependent on the individual switches (Ie, if pair one is switched off, the master switch does not light them up)?
  4. Jul 9, 2015 at 8:53 PM
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    The purpose of the master switch for my application would be to take the power away from the undividual switches unless the master switch was in the on position. If that makes sense.
  5. Jul 9, 2015 at 8:54 PM
    MDB Taco
    GA
    ‘05 TRDOR DC
    Oh okay. So you're wanting a master kill switch?
  6. Jul 9, 2015 at 8:57 PM
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Yes, basically. I want to be able to turn all the lights on or off with one switch vs. having to turn each switch every time, but also have the ability to select individual lights.
  7. Jul 9, 2015 at 9:00 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    The closest you can get to that (With a simple setup) is to have a master switch to run the power for each light switch off of, kill the master switch and all lights go out, turn on the master switch and all the lights with the switch in the on position come on.
  8. Jul 9, 2015 at 9:03 PM
    MDB Taco
    GA
    ‘05 TRDOR DC
    Okay. Give me a few minutes to draw a quick schematic with what I think should work.
  9. Jul 9, 2015 at 9:03 PM
    95 taco
    95 taco Battle Born
    With a 3 position relay where you have your relays and the master switch a 3 position switch you could make all the lights come on at once.
  10. Jul 9, 2015 at 9:04 PM
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    With running a relay setup though can't I just put the master switch to disconnect the power in line before the individual switches. With the master switch in the off position shouldn't it take away the power that the individual switches need to trigger the relays into the on position?
  11. Jul 9, 2015 at 9:09 PM
    MDB Taco
    GA
    ‘05 TRDOR DC
    I THINK this setup should work. It's similar to how I have my CB wired with its in-line kill switch.
  12. Jul 9, 2015 at 9:16 PM
    95 taco
    95 taco Battle Born
    Yes, the master switch will be the power switch for each light, no power to the switch=no power to the relay=no light.
    I think with a 3 position master switch and 3 position relays you can bybass the individual switches on 1 setting of the master switch and have current to every relay.
  13. Jul 9, 2015 at 9:20 PM
    MDB Taco
    GA
    ‘05 TRDOR DC
    Aight man, good luck!
  14. Jul 9, 2015 at 9:20 PM
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Perfect, thank you. I think that's what I was trying to draw, just way better. When all of my stuff comes in I'll put it together and update this thread.
  15. Jul 9, 2015 at 9:46 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Ome, Sqeak free dakars, arms, skids, sliders.
    I'm confused on the diagram. I'm assuming one feed is illumination? And not a double throw?
    If so looks good.
  16. Jul 10, 2015 at 1:09 AM
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    If you are talking about the switch, one wire goes to the relay, one is positive, and the other is a ground.
  17. Jul 10, 2015 at 6:19 AM
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I've got another question guys, ehat gauge wire should I use to build the harness? Can I use 16ga for the entire thing?
  18. Jul 10, 2015 at 6:29 AM
    DesertDunes
    DesertDunes Well-Known Member
    Cole
    Coachella Valley. CA
    2012 Super White Tacoma TRD OR DCSB
    Overland Stuff
    All depends on how many amp's/watts your light are pulling. between your circuit tap and switches 16 gauge is fine but your hot line running from your fuse box should be thicker depending on how many watts your going to be pulling
  19. Jul 10, 2015 at 6:33 AM
    DesertDunes
    Cole
    Overland Stuff
    Here this will help. I personally always go one size bigger if I can. [​IMG]
  20. Jul 10, 2015 at 6:40 AM
    MDB Taco
    GA
    ‘05 TRDOR DC
    Yeah, you can always use a bigger gauge, but a smaller gauge could be catastrophic. Calculate how many amps you'll be pulling and go from there.
