Help with changing wrong fluids
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ImthePrez, Nov 4, 2010.
  1. Nov 4, 2010 at 3:33 PM
    ImthePrez
    ImthePrez [OP] Well-Known Member
    TN
    06 Prerunner TRD
    So my younger bro said "Hey Ill change ur oil" So I let him but I walked out to see how things were going and the oil pan was red....he took out the 14mm tranny plug instead of the oil plug and now Im wondering what I should do?
  2. Nov 4, 2010 at 3:40 PM
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    Put the tranny plug back on, torque it, then refill the tranny with new fluid (about the same amount your brother removed) until the level is back to normal. Make sure you put the fluid in the right fill port. Remember to set the parking brake and leave the trans idling in neutral as you refill it back to normal level.
  3. Nov 4, 2010 at 3:40 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    nope, get it towed, i wouldn't touch my tranny with a 10ft poll, i'd let toyota do it
  4. Nov 4, 2010 at 3:41 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    Measure the exact amount spilled into the drain pan and go to dealer and buy some more(Toyota WS I believe) and add it back. Or look up "mountain lion's" excellent diy post on tranny flush procedure and replace it all. If you want a really warm fuzzy feeling inside replace with Amsoil ATL fluid. Lots of info and pics on here.
  5. Nov 4, 2010 at 3:50 PM
    ImthePrez
    TN
    06 Prerunner TRD
    Im so fucking pissed right now!! One simple thing turned into this....I HAVE to drive my truck tonight and dealship is closed...not a whole lot came out but still......so no autozone shit will work?
  6. Nov 4, 2010 at 3:52 PM
    payrow
    Los Santos
    '18 DCSB Sport
  7. Nov 4, 2010 at 3:53 PM
    ImthePrez
    TN
    06 Prerunner TRD
    oh and it gets better....he used the Mobil 1 oil I had but didnt change the old oil out...so now not only do I have to worry about the fucking transmission I have to drain the old/new oil and go buy more Mobil 1.. FUCK MY LIFE.
  8. Nov 4, 2010 at 4:02 PM
    ImthePrez
    TN
    06 Prerunner TRD
    guess ill have AAA tow it to toyota tomorrow morning...what should I expect to pay toyota for just refilling the tranny fluid? I know prices are gonna be different but a round about number would help?
  9. Nov 4, 2010 at 4:05 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Sounds like your brother needs some show and tell before being allowed near it again :eek:
  10. Nov 4, 2010 at 4:09 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Accidents always happen. Unless you can get that amsoil stuff, you are stuck. You need the right tranny fluid. Do not drive it with no fluid. Fortech (tw member) had a great diy pm changing the ATF. Real simple. If you have a lot of miles, tow it and have Toyota flush it. Low miles, just drain and fill. There are some things you will need to do to properly check thd ATF level. A drain/fill needs roughly 3 qts.
    When you drain your oil, keep in mind you have double the fluid. You need s oil pan that will hold all that.
    Best of luck.
  11. Nov 4, 2010 at 4:16 PM
    ImthePrez
    TN
    06 Prerunner TRD
    After he wakes up from his nap I beat him into
  12. Nov 4, 2010 at 4:19 PM
    ImpulseRed008
    Susan
    SC
    :laugh: how old is he? Make him pay the $$ damages and READ the owners manual cover to cover :eek:
  13. Nov 4, 2010 at 4:20 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    haha same thing happened to me. just got it towed and properly refilled with the right fluids.
  14. Nov 4, 2010 at 5:07 PM
    ImthePrez
    TN
    06 Prerunner TRD
    Thanks for the help on short notice guys! Im just gonna drain old/new oil and put new oil in it and looks like fucktard got the oil filter on ok...so thats good..then have it towed to toyota to just fill it up, and should be good after that.
  15. Nov 4, 2010 at 5:50 PM
    Airun
    Aaron
    Show Me State
    make sure the old filter he removed still has the rubber gasket on it and that its not stuck underneath the old filter or your gonna be out some more new oil.
  16. Nov 4, 2010 at 6:20 PM
    boss1041
    boss1041 Well-Known Member
    chad
    valdosta, georgia
    07 dc 6 speed trd or, 95 auto
    I thought ur supposed to put the transmission fluid into the cooling system lol. Sorry krazie I had too.
  17. Nov 4, 2010 at 6:22 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    If your brother needs a job, print out this thread, he can use it for a resume to get a job as oil changer at probably most jiffy lube/quick lube/walmart places, even a lot of dealers. Probably get hired on the spot if they need someone. Haha. j/k. It'll work out, make sure he learns from this.
  18. Nov 4, 2010 at 6:27 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    the procedure is on here.....but yeah i wouldnt touch it either
  19. Nov 5, 2010 at 9:59 PM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    when it comes to maintenance I seem to be retarded, but when I changed my oil I got it right the first time, when i read all the posts about people draining the tranny iso the oil it boggles my mind that i got it right,cause with my luck it should have been red oil pouring into the pan.
    hmmm,oil god was on my side that day,now only if the rear diff god
    is around:)
  20. Nov 6, 2010 at 12:50 AM
    tonyreo
    tonyreo Well-Known Member
    Tony
    N.E. Ohio
    Okay, I'm going to risk making myself look like a dumb ass but here goes.
    Our 2011 DC will be here in a few days so I am a bit ignorant on it yet.
    It seems to me that the tranny and oil drain plugs are very different, at least on my Camry they are.
    The tranny drain is a hex key (allen wrench) and the engine oil plug is a hex cap screw correct? Why are they so easily confused?
    Reminds me of a story:
    My (thank God) ex-wife bought a new Subaru and at 5K miles her father decided to change the oil. After he was done she and her mother went shopping and the car died on the freeway. They had it flat bedded to the dealer who found no fluid in the tranny and twice as much oil in the engine as there should be. That was a $6000 mistake! :eek:
