Help with Choosing Speakers & Sub
Discussion in 'Audio & Video' started by ZNIGZ, May 29, 2016.
  1. May 29, 2016 at 11:08 AM
    ZNIGZ
    ZNIGZ [OP] Member
    Albert
    2013 Tacoma
    3 inch Lift
    Hey guys I'm really new to this and don't know what products to get. I have a budget of around $1000 and wanting to keep the stock deck. I want to change all 4 speakers and get a sub. If anyone can point me in right direction or show me a thread where I can get information on a sound system that sounds great!
  2. May 29, 2016 at 11:22 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Check "My Audio Build". I priced out my install and it came to $997. I realize you have to buy two more speakers than I did, however, if you learn from my mistakes (mentioned in the build page) you would save $100-ish which could get you the remaining two speakers. Keep in mind I did all the work which saved me a ton in labor costs.
  3. May 29, 2016 at 6:12 PM
    zinger
    zinger Well-Known Member
    2016 Silver Sky Tacoma SR5
    I would recommend you contact Mr. Marv, he is very knowledgeable and should be able to set you up with a nice system. He has a couple threads going with his contact info. shown.
  4. Jun 5, 2016 at 10:20 PM
    jamiec
    jamiec Man who keep hands in pockets feel cocky all day
    Jamie
    Chillicothe, Ohio
    2017 Prius three touring. Sold the Taco
    I had my factory head unit for a while but I ended up swapping it out. When I had the stock head unit I replaced all door speakers except the tweeters and I added 2 10" subs and amp along with an audiocontrol lc2i line out converter. The line out converter is required when keeping the stock head unit.
    He was my setup,
    Jbl GTO 938 6x9's in front doors $60 Amazon
    Jbl GTO 628 6.5's in rear doors $50 Amazon
    2 PPI black ice 10" subwoofers $125 local
    500 watt Fosgate Punch amp $200 local
    eBay prefabbed sub box. $60
    AudioControl LC2i loc $90 Amazon
    If you go that route you'll get an amazing sound. However those prefab boxes are only half ass glued and nailed together with tiny nails. I got wood screws and buttoned it up so it would rattle.
    Also don't forget the speaker adapters for the door speakers as well as the wiring harness adapter which was another $20-$30
    My old setup will keep you way under budget.
    Good luck
