Help with climate control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Flash, Nov 11, 2011.
  1. Nov 11, 2011 at 3:11 PM
    Flash
    Flash [OP] Member
    Flash
    Whiteman AFB
    2011 Taco TRD
    TRD Exhaust, brush guard
    I just put a system in my 2011 tacoma, I removed the climate control head unit blah blah blah, and while I had the climate control out I decided to change the leds inside of it.
    I changed the outter two with no problem, so I proceeded to do the a/c and air cycle button ones, tore it apart, broke the spring on the speed switch in the process, realized it was to much, and backed out. Put it all back together, and re installed it, now its not working. i have no climate controls, no fans turn on, nothing. the only thing that works is I can press the air cycle button and it turns orange but doesnt do anything. So I know its getting power.....what do I do? I cant even find a climate control unit for sale.
  2. Nov 11, 2011 at 3:17 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hmmmm...only thing I can think of is maybe a wire got yanked off of something or a fuse.:cool: Its very possible there is more then one fuse for that location, I'd start there.
  3. Nov 11, 2011 at 3:22 PM
    Flash
    Flash [OP] Member
    Flash
    Whiteman AFB
    2011 Taco TRD
    Yeah I already checked the fuses but they are all good.=/
    I just tore it apart again. i am wondering if the spin dial on the back isnt making good enough connection....dont say the wire pulling thing.=/ thats gonna be super expensive. haha
  4. Nov 11, 2011 at 3:32 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I'm not sure then. I know you probably know your stuff but did you check the fuses under the hood too?
  5. Nov 11, 2011 at 3:53 PM
    Flash
    Flash [OP] Member
    Flash
    Whiteman AFB
    2011 Taco TRD
    Yeah I checked there. Thanks. I would rather everyone treat me like an idiot and give me an answer to fix my truck than assume I know it all and skip out on the answer. Called a parts place. The control box is only 250 bucks.=/ I think I have no other choice than to just go to Toyota and bend over. I can only imagine what they will charge to replace the wiring if its that.
  6. Nov 11, 2011 at 3:55 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Jeez $250? Thats crazy. Well good luck getting it fixed.
  7. Nov 11, 2011 at 3:56 PM
    Flash
    Flash [OP] Member
    Flash
    Whiteman AFB
    2011 Taco TRD
    Yeah thanks man. You wouldnt happen to know what year ranges would have the same climate controls would you?
  8. Nov 11, 2011 at 3:57 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Ummm I'm not sure about that one. It could be from 2005-2011 for all I know.:eek: Someone on here should know the answer.
  9. Nov 11, 2011 at 3:58 PM
    Flash
    Flash [OP] Member
    Flash
    Whiteman AFB
    2011 Taco TRD
    Thats what I was thinking. Any second gen should be the same. I hope.
  10. Nov 11, 2011 at 4:00 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah but I'm pretty sure 2012 changed their interior a little bit.
  11. Nov 11, 2011 at 4:03 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    the only climate control are the factory orange and those are 05-11 the new 12 actually has white lights behind it instead of the orange.
  12. Nov 11, 2011 at 4:12 PM
    Flash
    Flash [OP] Member
    Flash
    Whiteman AFB
    2011 Taco TRD
    Well the 2012 are also sexy black.haha They look so much better.
  13. Nov 13, 2011 at 8:08 AM
    Flash
    Flash [OP] Member
    Flash
    Whiteman AFB
    2011 Taco TRD
    So I do believe I figured it out, I took my handy dandy volt meter out there and started playing. its not my wiring. All I can assume is since I broke one plastic clip on the back of the control panel of by the circuit board on every time I removed it, which was 3 times leaving one clip left, it lost connection. New parts ordered. Coming from a 2006, its the entire center piece with trim and everything, and its black which is good because I hate the silver and wanted black anyways.
  14. Mar 14, 2012 at 4:27 AM
    anag
    anag Member
    Texas
    2011 pre-runner tacoma
    Do you know the part number of the light bulbs?
  15. Mar 14, 2012 at 4:54 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    There are a total of 4 lights in there? What lights are you wanting?
    Back ground or the buttons.
    Buttons a/c and circulating are a 5m
    http://www.superbrightleds.com/more...lue-led-15-degree-viewing-angle-5500-mcd/269/
    Background is a neowedge Base type
    http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/instrument.html
    Note that the neowedge base bulb that I showed is not a 360 degree bulb and will not light the whole background.
  16. May 2, 2012 at 2:37 PM
    esizzle777
    esizzle777 Son of Most High
    Laredo, TX
    16 TRD Sport
    hey blackshirts did you just PnP to make the ac and circulation buttons blue with the bulbs mentioned above?
