Help with diagnosing from a 2018 trd sport engine failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacofanboy8, Mar 4, 2024.
  1. Mar 4, 2024 at 5:57 PM
    tacofanboy8
    tacofanboy8 [OP] Active Member
    Alex
    2018 Tacoma TRD Sport - Cement
    none
    Hi all, here is my blurb that I have posted on a few other threads. I'm wondering if I could get some advice related to best guesses on what is going on based off of the diagnosis steps? Trying to figure out what could have led to this? (Linked post has mechanic notes)
    https://www.tacomaworld.com/threads...-a-2018-trd-sport.825957/page-2#post-29629627
    Here's the long story short
    2018 TRD sport Tacoma with 77k miles on it. Has been babied, no towing no off-roading just a daily driver stock, oil changes every 5k. Was driving back on a road trip and about 100 miles from home the engine light flashed while we were going 65 on the highway. Was driving super smooth beforehand, engine chugging and total loss of acceleration. Had to get it towed to the dealership near me and its still there here is where its at.
    What the tech has done so far
    -checked and replaced spark plugs
    -swapped coils and still got a misfire
    -said he checked all external parts for leaks
    -wet compression and dry compression tests done - low compression cylinder 2 (failed test)
    -cylinder 2 still had a misfire and used bore scope and saw scoring in cylinder 2 so sure enough needs a new engine
    I was shocked, babied the truck, oil change every 5k on the nose.
    Here's the kicker that would be really helpful if anyone can reply. I bought it CPO at 50k, so it has the 7 year 100k powertrain warranty. The dealership called Toyota Warranty to see if its covered and Toyota got back with they need to find the exact point of failure and do a teardown that can take up to 14 hours of labor. If they find it and send it to Toyota then it may be covered (though the powertrain would lead me to think it would be). Okay so Russian Roulette with 3k bill of labor and maybe coverage is leaving me super uneasy. Also, they thought initially it was spark plugs so they replaced them and I have a spark plus, labor, and 2 hours of diagnosing the engine failure after that, that could easily be 1.5---2k (I'm gonna fight for coverage but idk) It looks like thanks to this forum it is looking like I am in the boat of issues listed that should be covered. But if anyone can also let me know the treatment they got and what was covered to know what I should expect. I called Toyota Corporate and said I was incredibly disappointed with the potential 3k labor change and they are calling the dealership to see what they can do.
    Thanks all
    P.S. I have been added to the 2GR-FKS Engine Failure/Problems Thread https://www.tacomaworld.com/threads/2gr-fks-engine-problem-failure.774579/
    Superdave1.0 likes this.
  2. Mar 5, 2024 at 2:24 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Did you buy it new or used? Babied after you got it or from day one. If you bought it used, how do you know how it was treated?
  3. Mar 5, 2024 at 2:30 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Buying a used truck even if it is a certified preowned is always a gamble. Would also never buy used truck without first looking at the service records. Can only assume that oil change intervals were used, sticking pistons rings are most often attributed to the scoring of the cylinder.
    wilcam47 likes this.
  4. Mar 5, 2024 at 5:35 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Everything should be fully covered, since it's a CPO. I had 2 Lexus cpo and never had to pay a penny out if pocket. 1 was totally engine replaced 06 is250, and other was gs350 f-sport transmission replaced. The Lexus/ Toyota same cpo warranty.
    Anapg77 likes this.
  5. Mar 5, 2024 at 5:40 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Ok. That ain’t good.
  6. Mar 5, 2024 at 5:43 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I missed the extended warranty statement. You should be fine, it should be covered
  7. Mar 5, 2024 at 5:46 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    It the truck at a toyota dealer now?
  8. Mar 5, 2024 at 5:51 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    No guarantees of course but I would imagine it be covered, dealerships do have an obligation to say though that there is a chance it's not covered which would make you financially liable.
    Because it's only on one cylinder i'd say you're fine as from what I can picture with only one cylinder being damaged I don't see how a guy could cause that unless something was dropped and left in the cylinder at one point. If a guy had a torn air filter or something that could be prevented, all the cylinders would of probably been scored relatively equally.
  9. Mar 5, 2024 at 5:53 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Well that sucks!
    Another member got the lemon law thing after 3rd I believe motor failure.
    I’m at 57k on my 18 makes me nervous.
    They gotta give those 12 yr olds more nap time during their 18hr shifts.
  10. Mar 5, 2024 at 6:46 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    So here's my advice as a former toyota tech. It's covered. Their guessing at diagnosis is not your financial responsibility. Missfire on cylinder 2? Why wouldn't they just try swapping ONE known good spark plug? How is replacing 5 others going to help with a single cylinder miss firing?
    Personally, for me, I'd tell them to put your old plugs back in since it didn't fix it, take that portion of the labor off, diagnosis of a warrantable concern isn't your financial responsibility. You wouldn't pay for it under factory warranty and CPO is basically an extension of that. Tell them to pound sand. That is exactly why techs and dealers get a bad rap.
  11. Mar 5, 2024 at 6:55 AM
    IronMaidenJapan
    IronMaidenJapan So old I fart dust
    Lizardville
    23 TRDOR
    CPO with 50k….
    That’s all I needed to know and that makes the “5k oil changes” a moot point.
    However that warranty should take care of everything.
  12. Mar 5, 2024 at 7:22 AM
    tacofanboy8
    Alex
    none
    Hi all,
    Thank you very much for your input, its really appreciated. Just trying to get opinions from every angle. Great point saying the CPO isn't a guarantee, it was leased before hand with dealership taking care of maintenance. Great points on the spark plug charge they are trying to throw my way regardless, I will talk to the dealership and for sure talk to corporate if I get some push back.
    Yes the truck is still at the dealership, I am expecting to hear back from corporate today. I didn't want to okay the labor charge to investigate the engine failure without talking to corporate as I think they should be responsible for why their engine failed. I double checked my records and the last oil change showed full levels of all fluids...so if they happen to say I didn't have enough oil that is an oil leakage issue which is their problem and has been documented by other 2GRFKS owners and explained by the CareCare Nut. Although I have never seen any oil leakage coming from the car and I had a tech check last oil change since there was the high pressure fuel pump campaign.
    Hoping my luck turns around. Thank you!
  13. Mar 5, 2024 at 7:23 AM
    tacofanboy8
    Alex
    none
    Thanks this is great information to know!
  14. Mar 5, 2024 at 7:43 AM
    tacofanboy8
    Alex
    none
    Thank you for your input, this is really valued as as you have been in the technicians position.
  15. Mar 5, 2024 at 8:00 AM
    BlackCat81
    2023 Ice Cap TRD OR
    As long as you can prove you’ve maintained it from purchase date to current, you’re fine. The dealer is just being shady.
    Previous maintenance history should’ve been verified by selling dealer prior to CPO certification. Example, if a 2021 Tacoma is traded in with 25k, but has never had an oil change, then it’s the selling dealers responsibility to not certify that vehicle.
  16. Mar 5, 2024 at 8:20 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    They swapped his ecu as well..
  17. Mar 5, 2024 at 8:58 AM
    tacofanboy8
    Alex
    none
    Correct and luckily that is covered under the 80k emissions warranty
  18. Mar 5, 2024 at 9:24 AM
    Vlady
    Issy, WA
    But they were troubleshooting in the different zip code of the actual problem. It is a perplexing way to come to the conclusion that there is no compression.
    joba27n and jmneill like this.
  19. Mar 5, 2024 at 9:58 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Spitballing here. Did the air flap fail, and spit its guts in cylinder 2?
    Anapg77 likes this.
  20. Mar 6, 2024 at 7:17 AM
    tacofanboy8
    Alex
    none
    thanks for the insight, that’s reassuring. I guess I will authorize the tear down today to get information on why it failed.
    joba27n likes this.
