Help with front axle seal
Discussion in '1st Gen. Tacomas (1995-2004)' started by purple taco, Jul 6, 2011.
  1. Jul 6, 2011 at 2:23 PM
    purple taco
    purple taco [OP] Well-Known Member
    jesse
    gulfpot/biloxi
    99 ext cab SR5 4x4
    weapon-r intake,allpro 3"leaf springs,magnaflow exaust,ss break line,billy 5100's,allpro 1.5 greasable shackles,rear diff mod,u bolt flip kit,eibach 3"spring,light racing uca.blhm,plasti dip front/rear bumper, painted stock rims,04 gauge swap w/led,billet grill,tinted tail lights,bench to 4runner bucket seat,lockrite locker,bpv relocate,roof light bar/w 4hella 500ff,33x12.50r15 duratracs.
    How do I pull the seal out without damaging anything or getting any debris int the diff.
  2. Jul 6, 2011 at 2:36 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I tried to change my seal the other day and I wasn't sure how to get the seal out either. Mine is on the passenger side. Hopefully somebody can help us out.
  3. Jul 6, 2011 at 2:40 PM
    purple taco
    jesse
    gulfpot/biloxi
    99 ext cab SR5 4x4
    Mine is driver side. I tried to pull it out by hand. Well that didnt work out to well.lol
  4. Jul 6, 2011 at 2:43 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    There are seal pullers for that job, but it will always mangle the seal. You always replace a seal when you replace a shaft, even if it looks good or doesn't get mangled. It's $10 insurance for no leaks.
    This: http://www.amazon.com/dp/B0002SRCKG/ref=asc_df_B0002SRCKG1617437?smid=ATVPDKIKX0DER
    You can use a prybar too, if there's room. Center the new seal and drive in with a block of wood that is of the same size. Do not mangle or deform the seal installing it. Get a spare if you have doubts.
  5. Jul 6, 2011 at 2:43 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Have you pulled the axle out? :confused:
    ChadsPride likes this.
  6. Jul 6, 2011 at 2:49 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Slide hammer works well (if you have one).
    I popped mine out with a prybar with tape on the ends of it so as to not score anything. There's plenty of space to get in there with spindle/hub out of the way.
  7. Jul 6, 2011 at 2:52 PM
    kmok
    Kyle
    Columbus, Ohio
    Having the right tool would sure make it a lot easier lol. I changed both passenger and driver side cv axles and only the passenger side started leaking.
    The seal after pulling the cv axle out that goes between the differential and the axle.
  8. Jul 6, 2011 at 3:04 PM
    purple taco
    jesse
    gulfpot/biloxi
    99 ext cab SR5 4x4
    Thnx guys. Im gonna try the pry bar with tape.
  9. Jul 6, 2011 at 3:12 PM
    purple taco
    jesse
    gulfpot/biloxi
    99 ext cab SR5 4x4
    Man I love tw!!! Such a helpfull group of guys/girls.
  10. Jul 6, 2011 at 8:31 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Is there any easy way to get to this seal, or do you have to pull apart your front suspension and pull the cv axle out that way?
    I noticed my drivers side was leaking the other day so I guess I too will be getting to do this once to cools down a bit!
  11. Jul 6, 2011 at 9:57 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Pulling the axle is not difficult by any means. But yes, you have to pull the axle to get to the seal. You can wiggle around the coilover, but its only 4 bolts to pull the coilover out and it makes life easier so I suggest pulling the coilover off as well.
  12. Jul 7, 2011 at 9:52 PM
    kmok
    Kyle
    Columbus, Ohio
    I figured out the axle seal, the seal puller tool is very helpful. The metal part of the seal was rusted and became one with the differential so that really threw me off on changing out the seal the first time. I thought the seal was apart of the differential or something lo.
  13. Jul 22, 2011 at 5:46 AM
    rexver80
    rexver80 Member
    REX
    EMORY
    DLX TACOMA 4X4 EXTENDED
    5100s, 31-10.50-15
    did you guys get your seals from toyoyta, i cant find anyplace that stocks a aftermarket seal ?
  14. Jul 22, 2011 at 11:31 AM
    kmok
    Kyle
    Columbus, Ohio
    I went to Toyota and got mine. It was like $16, not bad.
  15. Jul 22, 2011 at 6:04 PM
    rexver80
    rexver80 Member
    REX
    EMORY
    5100s, 31-10.50-15
    can somebody give me the correct toyota seal part number, i went today to my local stealer and they gave me the wrong one , i am so tired of the run around and my guy at the parts counter is a sob, please
  16. Aug 30, 2012 at 11:27 PM
    YotaYota
    YotaYota Well-Known Member
    x2
  17. Aug 31, 2012 at 12:28 PM
    YotaYota
    anyone know the name of the seal between the differential and the cv axel?
  18. Dec 13, 2012 at 8:52 AM
    sixstringsteve
    sixstringsteve Well-Known Member
    Jaysjammin likes this.
  19. Dec 13, 2012 at 5:40 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    And for you guys pushing the seals in use seal drivers! Makes life a lot easier and you won't damage the seals. Also this is huge and took me 1 month and 4 sets of seals. The driver side push the seal all the way in till it stops. Push the seal all the way into the differential. As for the passenger side just push it in just enough so there is like an eighth of an inch of metal outside of the seal. So basically just push the passenger side in so there is a small lip of the outter housing showing. This is super
    Important because if you push it in to far you will leak every drop of oil right out the seal.
