Help with info on gears other than "D"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LouTaco, Nov 26, 2010.
  1. Nov 26, 2010 at 6:55 AM
    LouTaco
    LouTaco [OP] Well-Known Member
    Lou
    Des Moines, Iowa
    2018 T4R SR5 Premium
    I was wondering if anyone could help me find info or explain what the other gears "3" "2" "1" do and proper use because the manual is kinda vague at least to me it say for engine braking and greater engine breaking each lower gear i need help can someone break this down to caveman terms please :D
  2. Nov 26, 2010 at 7:22 AM
    PaidUpTruck
    PaidUpTruck Well-Known Member
    San Antonio, TX
    Tacoma TRD Off-Road 4x4
    Lower gears are used when you are towing and/or climbing a steep slope. It prevents the truck from automatically switching to the higher gear when you accelerate. It is also used to limit your speed going downhill sorta like a drag brake.
  3. Nov 26, 2010 at 7:27 AM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    I use "1" for going up my driveway. I have a very steep driveway and if I stay in "D", as I approach the top, the truck SLAMS into 2nd and really bogs down. It makes an awful sound if I don't down shift.
  4. Nov 26, 2010 at 7:44 AM
    myname150
    myname150 Well-Known Member
    I use 4 if i have a heavy load in the bed. Plus if your towing or climbing hills, like others said, it keeps you from not going than the higher gear selected. Or use it to keep your truck from gear hunting (IE: Shifting in and out of O/D and 4th)
    P - Park. (Use Parking brake when on steep declines or inclines)
    R - Don't use this at a stop light with people behind you :D
    N - Coasting / No Engine Power going to the Wheels
    D - Regular Driving
    4 - Some Engine Braking
    3 - More Engine Braking
    2 - Even More Engine Braking
    1- Most Engine Braking
    (for the four speed auto, it would be P,R,N,D,3,2,1)
  5. Nov 26, 2010 at 7:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Its just like the numbers for a Manual. 1st (L) is the lowest, while "D" is the 5th, or Overdrive.
  6. Nov 26, 2010 at 8:25 AM
    MMJ
    MMJ Well-Known Member
    Jack
    Denver
    2010 TACOMA TRD OFF ROAD
    Smitty Built nerf bars
    if i start off in 1 then shift to 2, then 3, all the way up to d in normal driving, is that possible without hurting the transmission? and if it is possible can i shift from d back down to 4, then 3, back down to 2 then 1 if needed without hurting the transmission? when doing this, am i suppose to let off the gas pedal then shift?
    these may be a stupid questions but i've always drove a manual my whole life and is new to auto transmissions...
  7. Nov 26, 2010 at 8:48 AM
    MMJ
    Jack
    Denver
    ok i see. and when u say hold the gas, do you mean keep the speed constant then shift to whatever gear i need? can u tell me what the speed limit is for each gear or can i tell by the rpm?
    thanks for the quick reply!
  8. Nov 26, 2010 at 8:49 AM
    crazyman
    crazyman Not bothered....
    Crystal Beach, FL
    '11 4x4 DC/SB TRD/OR V6 Auto, Magnetic Gray
    Does Plasti-Dip count as a mod ?
    I use 2 or 3 if I'm driving some sandy trails where the lower speeds are required. Less shifting. Plus I don't give too much power when climbing.
    Normal street driving is in D. I sometimes drop it down to 3 or 4 if I need to pass quickly.
  9. Nov 26, 2010 at 8:50 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The transmission wil not downshift to an incompatable gear range. Ie. Cruising at 65 mph, you can select 1st but it will not shift down that far. Starting off in 1st, you can wind out that gear and it will shift into 2nd.
    Manually shift all you like. I manually downshift when going downhill or slowing down in snow (when I drive an auto).
  10. Nov 26, 2010 at 8:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. Coasting in Neutral in an Auto tranny is Bad.
  11. Nov 26, 2010 at 8:59 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Remind me as to why, please.
  12. Nov 26, 2010 at 9:01 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Holding the gas I believe means don't give it any when your shifting (at least that's what the owners manual mentions.) The speed limits for each gear are listed in your manual (and keep an eye on the tach.) I mainly use the lower gears for engine braking, dropping down to 4th if the tranny is searching going up a grade, and while offroading. If your truck is equipped with downhill assist you need to be in 1st or 2nd with the auto tranny while in 4LO for maximum effectivness.
  13. Nov 26, 2010 at 9:06 AM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink 5100 Blinstein set at 2.50 1" procomp rear block with TSB leaf pack. 5100 Blinstein on back 17x9 kMC wheels 0 BS 285/70 17 Nitto Terra Grapplers G2
    I would like to know too
  14. Nov 26, 2010 at 9:07 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    seriously? I've always been a fan of popping it into neutral when going down hills where its a straight shot and wont have to make any sharp turns. I've found that by leaving it in gear and coasting the engine slows it down too much sometimes, where as neutral keeps the speed more constant (on certain hills) with out having to keep my foot on the pedal.
    If it is actually BAD , I would like to know why.
    thanks!
  15. Nov 26, 2010 at 9:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    THe Tranny fluid pump is driven off the engine (output shaft going into the torque converter). When you put the auto in "N" and coast, the pump is not able to circulate the fluid thru the tranny as it should, but with the rear wheels still spinning (as your coasting), the tranny gears and other internals are still turning, generating heat. Without the fluid circulating thru the tranny from the pump, the tranny can quickly over heat, and be damaged.
  16. Nov 26, 2010 at 9:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  17. Nov 26, 2010 at 9:28 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    The pump still pumps with the engine running. It does not matter which gear you are in.
  18. Nov 26, 2010 at 9:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cool:
  19. Nov 26, 2010 at 11:19 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I fail to see how more wear and overtemp will occur. The clutches are disengauged. The pressure is regulated, or else it wouldn't shift at idle. Fluid temp is still being regulated.
    The only part which generates significant heat is the torque converter, which is idling. Fluid is still cycling through all the bushings at pressure, which is still lubricating it. It is also going through the radiator, cooling it.
    I don't believe the oil pressure analogy since the pressure is regulated, by the engine and by the transmission. You have to control pressure to control shifts.
    I have been wrong before, I don't see how I am wrong now. Maybe someone can enlighten me, if I am;)
  20. Nov 26, 2010 at 4:59 PM
    DBZ
    DBZ Hunter-Gatherer
    South Georgia
    2010 DC PreRunner TRD Off Road
    Fog lights anytime, DIY shorty antenna, carpet lined storage bins, debadged, tailgate hoseclamp, DIY washable cabin filter, AFe Pro-Dry air filter, Protecta bed mat
    Going back to the original question, I always thought "2" was used in slippery conditions (snow, mud). In the "2" position the transmission would start off in second gear, applying less power to the wheels and resulting in less wheel spin.
    I don't have my manual in front of me, but that's how I recall it working in most vehicles.
