Help with Intake decision...
Discussion in '4 Cylinder' started by StormTrooper, Jan 21, 2010.
  1. Jan 21, 2010 at 8:37 PM
    StormTrooper
    StormTrooper [OP] Well-Known Member
    Ron
    Maryland
    08 Base Flowmaster Super 44 w/ K&N drop in
    Bed Cap,K&N Air Filter,Chrome Pieces,Flowmaster Exhaust,Neon on inside, Heavy Duty Custom Floormats ( Tacoma ), Tint 20%, Blue license plate lights, Various decals, LED Projector Halos headlights, JVC head unit stereo
    Im looking at an AFE stage 2 cold air intake. now it says it goes from "Stage Two kits replace the entire intake tract all the way back to the Turbo or intake manifold, providing the ultimate level of fresh, clean, cool air to boost your performance." ... even tho i dont have a turbo, and my entire engine is stock except for exhaust ( muffler ) would it fit?
  2. Jan 21, 2010 at 8:42 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    yes itll fit, but seriously recommend saving the money delete the secondary filter and just get the pro-dry S drop in filter
  3. Jan 21, 2010 at 8:43 PM
    StormTrooper
    Ron
    Maryland
    send me the link? cuz im not clear on what ur saying - no offense
  4. Jan 21, 2010 at 8:44 PM
    StormTrooper
    Ron
    Maryland
    oh damn, u mean a drop in like k&n drop in? i already have that in
  5. Jan 21, 2010 at 8:48 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
  6. Jan 21, 2010 at 8:58 PM
    StormTrooper
    Ron
    Maryland
    so i shouldnt get the cai?
  7. Jan 22, 2010 at 4:11 AM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    not unless you have extra money laying around, and in that case u should send it to me, youll get about the same gain from it!
  8. Jan 22, 2010 at 4:57 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    They sound nice. I had one, got rid of it and got he aFe drop in filter. Removing the secondary filter has gotten mixed reviews from members here on the V6. 4cyl seems to do better.
    Are intakes are already a CAI. It gets the air from the fender instead of the engine compartment. It is tuned to reduce noise and provide power in the lower RPM bands.
    A new CAI will sound louder as it is not tuned to keep noise down. Also, it is tuned to provide power in the upper RPM bands. You will lose some in the lower RPM's. Also, the way are engines work the brain will mix the air and fuel together. Our ECU has it set at a constant factor no matter what. So if you add more air, the ECU will add more fuel to keep the Air/Fuel ratio that constant figure. You will burn more gas w/o any real gains.
    Now, if you want to modify the A/F ratio, you will see better gains. Nothing earth shattering. Anytime you mod the intake/exhuast you are messing around with the factory settings. If you don't modify those settings, any gains you might get will be pretty much wiped out.
    You have the K&N, just keep that. Keep it clean and do not over oil.
