Help with lack of power to engine
Discussion in 'Technical Chat' started by toytaco1, Apr 5, 2011.
  1. Apr 5, 2011 at 8:23 PM
    toytaco1
    toytaco1 [OP] Well-Known Member
    jed
    moreno valley
    05 supercharged trd off road
    trd supercharger, TRD intake, magna flow exhaust, JBA headers, walker evans front, fox rear, leaf pack, drilled slotted rotors, All Pro Front Bumper, Warn 8000 Winch
    Before i deployed recently my truck registered a P0010 code I had my bro take it to the dealer and they fixed it saying it was an oil sending unit. After The truck ran great for two trips one to the house from the dealer and one to the store, when my brother started it at the store it lost all power and wouldnt excelerate past 30 mph.
    He took it back to toyota a second time and they said the catalytic converters were bad and that there was low volts to bank 1 and bank 2. I am going to speek with them on the phone tomorrow and find out exact codes just wanted some input.
    I am thinking that they forgot to re connect something or there is a vacuum leak or MAF problem, any advice would help.
  2. Apr 6, 2011 at 8:34 AM
    pyro13g
    pyro13g Well-Known Member
    Will
    Florida
    07 Tacoma Access Cab 4-CYL 5-Lug
    2.5" Lift, Add A Leaf, ridding on 30's, Sound Mat in floors and doors
    Please let me know what you find out! I have bad mpgs and I know its related to vacuum and or computer problems... I have rest the computer on it and it runs good for a day then returns to shit...
  3. Apr 6, 2011 at 4:22 PM
    toytaco1
    jed
    moreno valley
    I'm gonna call tomorrow and speak with them, I'm thinking they unplugged my maf and forgot to re connect it.
    To me it sounds like you might want to clean your maf
  4. Apr 7, 2011 at 10:31 AM
    pyro13g
    Will
    Florida
    If your MAF was unplugged it would not run. I had mine in backwards once and it wouldnt start. I have cleaned mine out using MAF cleaner... still sucks. I know it must be a vacuum issue since it runs even worse with the A/C on. It also shudders a little when im breaking at a light. I know its not my drive line since I shifted it into neutral and would break to a red light and no shuddering was felt. So my conclusion is that some vacuum is messed up...
  5. Apr 7, 2011 at 6:36 PM
    toytaco1
    jed
    moreno valley
    I replaced my air fuel relay and fixed the problem
  6. Apr 8, 2011 at 8:57 AM
    pyro13g
    Will
    Florida
    Air fuel relay? Where did you find this at?
  7. Apr 8, 2011 at 11:04 AM
    toytaco1
    jed
    moreno valley
    It is in your fuse box under the hood its called the air fuel heater relay, try swapping it with your fog relay located in the fuse box might do the trick. Worked for me
