Help with lift situation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by twoodcc, Sep 20, 2011.
  1. Sep 20, 2011 at 7:25 AM
    twoodcc
    twoodcc [OP] Well-Known Member
    Alabama
    2008 TRD Offroad Prerunner
    I have a 3" rough country lift on my 2011. I was told the ride would be the same, but I think the ride is stiffer. Also, my truck squeaks when you get in or out of it. Is that from the lift?
    I see that most people don't recommend a spacer lift, which is basically what I have. Should I take it off an buy another lift that costs even more?
    I called the local dealer, and they do 3" body lifts - a trailmaster. Anyone heard anything about this brand?
    What's the difference between a body lift and suspension lift?
    Thanks
  2. Sep 20, 2011 at 7:37 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Plug both of these "body lift" and "suspension lift", into the search bar. You'll have hours of reading.
    Frank
  3. Sep 20, 2011 at 7:41 AM
    sambojee
    sambojee Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    I wouldnt get a body lift or spacer lift. i did one of the cheapest ways possible and got the Bilstein 5100s set at 2.5 in the front and got a rear AAL in the back. Which means the front is all stock except for the shocks. i got alittle less than 3 inches of lift. Ive had no problems with this so far and its been about 8 months now. If u have any questions feel free to pm me.
  4. Sep 20, 2011 at 7:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The squeek is most likely from the leaf springs and many members have the same squeek, lifted or stock.
    I'd stay away from body lifts... yeah, just stay away. They look like crap and can be unsafe.
    Spacer lifts work, but there are much better options available as sambojee mentioned above. How high are you looking to lift, what do you use the truck for and how much do you want to spend on a lift?
    Also, have a read through this. It will explain some of your options.
    http://www.tacomaworld.com/forum/suspension/11282-tacoma-lift-faq-guide-read.html
  5. Sep 20, 2011 at 7:54 AM
    twoodcc
    Alabama
    Well it seems to me that a body lift and spacer lift are very similar. I think my rough country lift is some sort of suspension lift, since they did have to align it after the lift was installed.
    But if I jump in the back of my truck, it squeaks. Is this from the lift, or is it the squeaky leaf issue?
  6. Sep 20, 2011 at 8:01 AM
    Pugga
    Massachusetts
    A body lift and a spacer lift are nothing alike... A body lift shoves a spacer between the body and the frame, a spacer lift either preloads the front coils or is mounted on top of the front strut to space the front suspension down.
    The leaf spring squeek is not necessarily caused by the lift. Try pressure washing between the leafs to blow out any dirt. Sometimes that's all it takes. You have a 2011, the dealer might be able to do something about the squeeky leafs. If not, you can try this out:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/98055-diy-squeaky-leaf-fix.html
    Remember, the search function is your friend :thumbsup:
  7. Sep 20, 2011 at 8:02 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    YOu spent around 30k for your truck. spend a little more money and lift it the right way instead of going the cheap route.
  8. Sep 20, 2011 at 8:17 AM
    twoodcc
    Alabama
    Thanks for the reply! Ok so do I need to take it into the dealership for the leaf squeak?
    I only want about a 3" lift. I do some light offloading and camping mainly. I already have the spacer lift. Should I just keep it?
    I don't want to spend a ton of more money on a lift, but if it's worth it then I'm open to considering buying another lift. I do plan on putting bigger tires on it eventually also
  9. Sep 20, 2011 at 8:21 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Your questions have been answered about 3 times in this thread alone... re-read, and then type some stuff in the search box you see towards the top right of this window.
  10. Sep 20, 2011 at 8:41 AM
    Pugga
    Massachusetts
    If you want the dealer to try and fix it, yes, take it back. It's a new truck, they might be able to help you out. If you're feeling handy, you could fix it yourself using a pressure washer and the DIY link I posted.
    Read this on your spacer lift.
    http://www.camburg.com/toyota/00-06-tundra/read-before-buy-spacer-lift/
    That's obviously the worst case and keep in mind Camburg makes higher end suspension components so you wouldn't expect a cheap spacer lift to live up to their expectations. Spacer lifts do work and plenty of people here have them but there are precautions. If you wheel your truck, spacer lifts are not for you. You could end up blowing out your shock when wheeling with a spacer lift. If you stick to pavement or maybe a dirt road, you'll be fine. There are much better options but, like you said, you already have the spacer lift installed...
    One thing to keep in mind also, when you start pushing the 3" of lift, you might need new Upper Control Arms to get your alignment within spec.
  11. Sep 20, 2011 at 10:19 AM
    twoodcc
    Alabama
    Thnks again for the reply.
    I do like to drive off-road, but I probably only do it a few times a year. But it sounds like I could tear it up in those few times. I don't go on any crazy trails, but I do more than just dirt roads.
