help with MAF sensor
Discussion in '1st Gen. Tacomas (1995-2004)' started by je99tacoma, Jun 3, 2012.
  1. Jun 3, 2012 at 11:40 AM
    je99tacoma
    je99tacoma [OP] new member
    Jonette
    Olympia, Washington
    99 Black TRD Off Rd SR5 Extended Cab
    All origiinal
    I'd like to know how to replace an MAF sensor? Does it require just unplugging? Or a new wiring harness? I've already cleaned it with the spray from CRC, but it still shows that it as running too lean. I realize this sensor measures the air density. It's been very humid here the past week or so, if the sensor was not completely dry before I put it back in, could that have anything to do with it? Changed out the fuel filter yesterday, runs great after driving for awhile CEL popped back on. Any ideas?:confused:
  2. Jun 3, 2012 at 12:58 PM
    Madjik_Man
    Colorado Front Range
    Don't quote me on this, but I think I've read here that after you do that (and/or clean the throttle body, etc) you need to reset the ECU.
    I think you do that by disconnecting the battery for a while.
    But I'd let others chime in for more experienced advice.
  3. Jun 4, 2012 at 5:57 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    I've cleaned mine twice and didn't have to reset anything.
    What code is it throwing? Mine was throwing P0171.
  4. Jun 4, 2012 at 9:52 AM
    je99tacoma
    Jonette
    Olympia, Washington
    All origiinal
    Even after changing out the fuel filter. So I just opted to pick up another MAF sensor for about $80 with core. Popped it in.... Easy. Drove to work this AM; no problems. My truck has about 130,000 miles on it. Hope this does the trick; sounds as good as the day I bought it.:)
  5. Jun 4, 2012 at 4:01 PM
    Gooch
    Orange County CA
    Awesome.
    BTW, what air filter are you running? I had the TRD for years and it seemed to dirty up the MAF sensor. I heard the same thing about the K&N.
    I'm back to the OEM style now and am perfectly happy with it.
  6. Jun 7, 2012 at 12:31 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    X2 I ran the K&N and it dirtyed up mine also. I have gone back to the OEM aswell. I have cleaned my MAF about 3or4 times now and all I do is unplug it and remove the two screws and spray it with CRC MAF cleaner let it air dry and reinstall it. I have never reset the ECU. I also clean my T.B. at the same time.
