Help with ODB II update cycles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ikunat33, Jan 22, 2019.
  1. Jan 22, 2019 at 9:19 PM
    ikunat33
    ikunat33 [OP] Active Member
    Vancouver BC
    2006 Tacoma base model
    HI All,
    I am new to Toyota vehicles, and Tacomas, and ODB II so I hope someone out there can give me an idea of how to proceed with some codes I have received.
    The truck runs fine but seems bogged down now and then. I can hear a constant and sometimes loud ticking but I understand this to be the VVT so no concern (at least the Toyota tech doing the pre purchase inspection seemed to think it was normal)
    My ODB Reader is a Bluedriver.
    The codes I get are:
    2 Confirmed Codes:
    P0022 "A" Camshaft Position - Timing Over-Retarded Bank 2.
    P0420 Catalyst System Efficiency Below Threshold Bank 1.
    4 Pending Codes:
    P0012 "A" Camshaft Position - Timing Over Retarded Bank 1
    P0022 "A" Camshaft Position - Timing Over Retarded Bank 2
    P0430 Catalyst System Efficiency Below Threshold Bank 2
    I understand this to indicate that I most likely need to change my timing chain and also that my CATs are probably burned out. (something about pushing hotter than normal exhaust if the timing is out)
    Soo... if all above is correct then why, after clearing the codes last week, would the Catalyst codes take 3 days to come back and the camshaft codes take a week to show up again??? Oh.. and can anyone tell me how a code can be pending and confirmed at the same time?
    BTW I cleared the codes as one mechanic said It could just be the truck had not been getting timely oil changes and running it with new oil for a while could address deposits causing the codes. He said to run it for a month or so then clear the codes and see if they come back.
    Sincerely,
    Sean.
  2. Jan 22, 2019 at 9:40 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    TomTwo and JD_P like this.
  3. Jan 24, 2019 at 5:56 PM
    ikunat33
    Vancouver BC
    Thanks jimmyh,
    I will pick up the oil and filter and inspect those parts in the next few days. Once the problem has been addressed should the engine light go out by itself or will I need to clear the codes again then wait and see??
  4. Jan 24, 2019 at 6:05 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Someone needs to put a manual gauge on your engine and see what the real time oil pressure is. Your P0022 code could easily be from low oil pressure and the oil pump could be going out. You are correct after you make repairs you will need to clear your codes.
    I just went through the same issue and code on my Son's 2007 Tundra and had to replace the oil pump to resolve the problem.
    Please keep us posted as to what you find and what you did to fix it.
    Jimmyh likes this.
  5. Feb 8, 2019 at 5:10 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    P0022 just came up on my wife's Tacoma, so very interested in the fix here.
    Also, thanks Jimmyh for posting all of the informative PDF's.
    Jimmyh likes this.
  6. Jun 26, 2019 at 5:08 PM
    mandatoryfun
    mandatoryfun Member
    OP please post an update, did you get this resolved?
  7. Jun 26, 2019 at 5:16 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    For me, I pulled the passenger bank OCV filter in my wife's 06. It was pretty clean so I didn't pull the driver side. I ran a couple caps of Sea Foam in the oil for 50 miles, changed it and cleared the code. It hasn't come back on again.
  8. Jul 5, 2019 at 8:29 AM
    mandatoryfun
    mandatoryfun Member
    Update: P0022 is back and now brought P0010 along for the ride.
  9. Jul 5, 2019 at 8:40 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    What have you done to address the P0022?
  10. Jul 5, 2019 at 8:45 AM
    mandatoryfun
    mandatoryfun Member
    Changed the oil, checked the OCV screen (it was clean), cleaned and power cycled the original OCV (this didn’t fix it), replaced the bank 2 OCV (this also didn’t fix it).
  11. Jul 5, 2019 at 8:54 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    With all that work to the system, I would try clearing the code one more time with my fingers crossed it doesn't return. Not very helpful, sorry, but that's all I got.
  12. Jul 5, 2019 at 8:58 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm not here to contribute anything helpful. Just here to laugh at the title... Hahaha... ODB.
  13. Jul 5, 2019 at 3:52 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You would be surprised at how many time this is mixed up....
    12TRDTacoma[QUOTED] likes this.
  14. Jul 5, 2019 at 4:06 PM
    mandatoryfun
    mandatoryfun Member
    I just got the joke by independently figuring out I screwed up. I replaced the bank 1 OCV originally. I compounded that mistake by using a Gates brand OCV. It lasted 5 days and took a shit. The P0010 is from the shit quality Gates solenoid dying. My P0022 is from the real bank 2 (driver’s side) OCV.
    I am replacing them both with Toyota OEM parts tomorrow morning
    Jimmyh[QUOTED] and DesertRatliff like this.
  15. Feb 3, 2020 at 7:15 AM
    Chiloquin_Car_Care
    Chiloquin_Car_Care homie dont play that
    Oregona
    2021 voodooblue DCSB 4x4 3.5l v6
    nada....maybe a license plate one day & BA bumpers
    I just joined the p0022 club....my mentor/auto wiz in socal suggested something similar to your remedy
    how many miles have been put on the your wife's taco since the sea foam treatment?
    did the p0022 code re-appear since your last post on the matter?
  16. Feb 3, 2020 at 12:22 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    It's been a while. The CEL occurred around Thanksgiving. She puts about 300-400 miles on the truck a week...been 11 weeks. So there could be as much as 4k miles on it and it hasn't come back. It is the 2nd or 3rd time it's happened owning the truck the last 8 years and always happens on long trips where oil has been up temp for a few hours and with dirty oil (4k+ miles on the oil change). I clear the code, change the oil and it doesn't come back for a long time. Hopefully the added Sea Foam before an oil change here and there will keep it in check. Truck has 196k on it now and we plan on keeping it another 5 years or so, especially knowing yours has gone as far as it has.
  17. Feb 3, 2020 at 2:56 PM
    Chiloquin_Car_Care
    Oregona
    appreciate the response bud....I am going to try the sea foam approach & hope for a resolve
    some insight on my taco/p0022 code-
    my CEL was on for a mere 5 miles & then turned off
    have not seen it since (drove 300-400 miles up to now)
    1st & only time in 350k+ miles having this CEL
    maybe a fluke CEL?
    wondering if I am getting myself worked up over nothing?
  18. Feb 3, 2020 at 3:29 PM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Hmm. I would keep my eye on it but not worry much. Maybe clean the screens if it came back again. I know you change your oil religiously, and it seems with what I've read, that helps in this case. Ours just seems to be a fluke too, and now that I think about it, the CEL disappeared by itself on one of the 3 occasions I mentioned earlier. Good luck! Keep us posted!
  19. Feb 3, 2020 at 6:17 PM
    Chiloquin_Car_Care
    Oregona
    nice
    thanks for all your help & info on this matter, super sweet
    I really appreciate it & people like you here on TW
    you rock buddy!
  20. Feb 3, 2020 at 6:36 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    FWIW, I had oil control valves stick on an Outback xt (subaru OCVs look almost Identical to Toyota’s) and I removed them and cleaned them and then let them soak in pb blaster. Between that and using rotella T6 oil(mainly for blow by, but is higher detergent being a diesel oil) The codes never came back for atleast 30k miles till I sold it and bought my Tacoma.
    Chiloquin_Car_Care likes this.
