Help with oil filter 2010 SR5
Discussion in '4Runners' started by TNDrew, Aug 4, 2012.
  1. Aug 4, 2012 at 4:11 PM
    TNDrew
    TNDrew [OP] Well-Known Member
    Drew
    Chattanooga, TN
    '12 Reg Cab 4x4 Silver
    WeatherTech DigitalFit Liners, Bench Seat Angle Fixed, Fog Lights (Nokya 2500k HyperYellow bulbs), aFe ProDry drop in, DeeZee bed mat, UWS black low pro tool box, Marathon Seat Covers (ordered should arrive mid-May). iSimple iPod adapter, Blacked out badges, SockMonkey WhiteTail Toyota Horns decal, LED Dome and License Plate Lights (LEDSolutions), Black Headlight Mod,
    Sorry if this has been covered, but we've been having my wife's oil changed at an oil change place since she got it because I have never dealt with the type of oil filter thats on it. How in the hell do i change it? Is there a write up on here or is it easier than I think. I'm not the most adventurous when it comes to dealing with something on an automobile that I've never done or seen done.
  2. Aug 30, 2012 at 5:52 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    First get yourself one of these valves!
    http://www.fumotousa.com
    Buy your filter at toyota and use the oil of your choice!
    There is a write up somewhere on how to do it! It's super easy and way cheaper to do yourself!
  3. Aug 30, 2012 at 6:04 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
  4. Aug 30, 2012 at 6:06 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
  5. Aug 31, 2012 at 3:02 AM
    topneck
    topneck Part Time Bivalve Extractor
    South Jersey
    06 Reg Cab 4WD
  6. Aug 31, 2012 at 5:04 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    The 4.0 on the 4Runners is the Dual VVT-I and is does not have the oil filter on the top of the engine. It is a filter element that sits encased in a enclosure under earh the fan pulley.
    You need. 3/8" drive to remove a cap and insert a special tool that comes with the filter element to drain the filter housing and remove the O ring. Once that's do e you'll need a special filter housing wrench to remove the housing. It's similar to the oil filter one that fits the normal filter but is a hair different. There is a metal tab on the housing you have to removed before you do remove it. Once removed replace the filter element and O rings put everything back together and torque to spec. Remember to oils the O rings though.
    Skid plate under the engine does have to be dropped to do so though.
