Help with picking a Susp lift for 03 yota
Discussion in 'Suspension' started by YotaGrl, Jun 17, 2009.
  1. Jun 17, 2009 at 4:48 PM
    YotaGrl
    YotaGrl [OP] Mud Queen
    Cali
    03 4x4 White Tacoma 5Sp
    Alright,
    So I have an 03 Ext Cab Taco. I dont know a whole lot about lifts, only that since im an off roader I DONT want a body lift. I do want to be able to fit 33's on it. So from what I have read 3' susp lift looks like the way to go.
    Now my problem... I have been looking at the diff Susp lifts, and i have no idea whats good.
    :help:
    Like i said this truck is for offroading NOT SHOW! so susp lifts only.
    Thank you!
    :wave:
  2. Jun 17, 2009 at 6:49 PM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    Hey I too am looking at lifts and the little that i know ARB stuff seems really good. Most olders posts if you search thru them I see OME alot and only read good things. If you go to ARBUSA.com they will send you a free catalog with dealer contact info and you can get a parts list from the web site for your truck, free to print off . not much info but a place to start. Good luck
  3. Jun 17, 2009 at 9:12 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    So Your ganna want to go with a Coilover lift, and either AAL or full leaf pack for the rear.
    Toytec, Sway-A-Ways, and Icon... I think, make real good coilovers for our trucks.
    You check out Toyteclifts.com...And WheelersOffroad.com
    Great products and prices!!!
  4. Jun 17, 2009 at 9:53 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    what kind of offroading are you planning on doing?
    what part of Cali are you in?
    different regions, different terrain call for different types of set ups...
    what works in one area of wheeling, may not work as well in another and vice versa...
  5. Jun 18, 2009 at 6:23 AM
    YotaGrl
    Cali
    I live in northen Cali. Im looking to do desert kinda stuff. No rock crawling. Thats what my friends are into.
  6. Jun 18, 2009 at 7:10 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    I suggest coilovers from ToyTec to Sway-A-Way to Camburgs to Icons for the front and a full custom leaf pack for the rear w/ some nice resi. rear shocks. Give us a budget.
  7. Jun 18, 2009 at 12:37 PM
    YotaGrl
    Cali
    Budget hmmmm 600 or under? But i want some that will hold up.
  8. Jun 18, 2009 at 12:40 PM
    tmat
    tmat Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    mmm...good luck with that. A good leaf pack in the back will cost you $600 alone. Doing stuff to your tacoma aint cheap
  9. Jun 18, 2009 at 12:41 PM
    sirsaechao
    Tim
    Commifornia
  10. Jun 18, 2009 at 12:58 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    at bare minimum, i would strongly suggest looking into higher end coilovers like Kings, SAWs, Camburg, or Icons for the front, and a full 8 leaf pack with resi shocks in rear...
    figure front end alone will run about $800 to $1,200 and rear will run about $800...
    PM me for shortcuts though...
