Help with rear bumper
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ak4T777, Feb 17, 2017.
  1. Feb 17, 2017 at 7:26 AM
    Ak4T777
    Ak4T777 [OP] Well-Known Member
    Kevin
    2003 Tacoma crew cab
    OME lift 3" lift 1.5" lift shackles Aftermarket bumpers 1" body lift
    I love Box Rockets old truck and found an old pic yesterday of a bumper rebuild that he did. (See pic below) I reached out to him but no reply back yet. I'm picking up materials today, building tomorrow and I'm wondering if anyone knows the size of square bar he used and diameter of tube? Maybe 2"×5"???IMG_0949_zps7c99e921.jpg
    outlawtacoma and ChadsPride like this.
  2. Feb 17, 2017 at 8:51 AM
    Wulf
    Wulf no brain just damage
    Kira
    1789 28th St, Boulder, CO 80301
    rock raisin
    Really tough to guestimate from a chair, you could probably measure that height and approximate it. Looks like 2x6 or maybe 2x8 square tube, 2" dia tube
  3. Feb 17, 2017 at 8:59 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    You could take this picture combined with other pictures and measure distances on the truck like the bottom of the sheetmetal to the bottom of the brake light housing and use that to determine scale.
    Also @Fernando might be able to help.
  4. Feb 17, 2017 at 9:36 AM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    did you look at his build, I just glanced at it and it mentioned 2" tubing along with 3x5 square tubing
  5. Feb 17, 2017 at 9:36 AM
    natas1321
    natas
    san antonio
  6. Feb 17, 2017 at 9:38 AM
    Croth51
    Croth51 Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Im pretty sure I use 3×5 1/2 for my bumpers...IMG_20170114_092037_948.jpg
  7. Feb 17, 2017 at 9:56 AM
    Ak4T777
    Kevin
    I think that's his old bumper build you're mentioning. That bumper sticks way out compared to the one I pictured above
  8. Feb 17, 2017 at 9:57 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Looks like 2x6 and 1 1/2" tubing
  9. Feb 17, 2017 at 10:07 AM
    Ak4T777
    Kevin
    Adam (Box Rocket) just replied back to my message. 2x5. Not sure about tubing since i didnt ask. Oh well. Thx for the help!
    RedManRocket likes this.
  10. Feb 17, 2017 at 3:17 PM
    Ak4T777
    Kevin
    Picked up the materials after work today. Fun begins tomorrow! 20170217_161134.jpg
    Croth51 likes this.
  11. Feb 17, 2017 at 3:29 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Is that 2x6?
  12. Feb 17, 2017 at 4:38 PM
    Ak4T777
    Kevin
    No sir 2x5
  13. Feb 18, 2017 at 8:46 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Doesn't look to me that the pictured bumper will protect much of anything, what with being practically even with the tailgate, but... :notsure:
  14. Feb 18, 2017 at 7:39 PM
    Ak4T777
    Kevin
    Way more protection than just a roll pan. Glad I didn't go that route like I was planning on doing. Very pleased with how mine turned out! My older brother sure knows how to weld! Didn't get a chance to bend the DOM tubes for the sides yet. No acess to the bender today. 20170218_172928.jpg
  15. Mar 2, 2019 at 8:45 AM
    2003blacktaco
    2003blacktaco Well-Known Member
    Bay Area
    03' Black Sand Pearl Tacoma SR5 Prerunner Stepside
    12" Sub with Pioneer DEH-X4800BT.
    Sorry this is a little late, this is his exact words on a forum from him on rme4x4 “ I used some 3x5 rec tube for the main section, cut in a receiver and added some 2" tubing around the corners for a little bed protection.”
  16. Mar 2, 2019 at 8:51 AM
    2003blacktaco
    Bay Area
