Help with rear end NOISE.
Discussion in 'Suspension' started by crushsouls33, May 12, 2012.
  1. May 12, 2012 at 12:27 PM
    crushsouls33
    crushsouls33 [OP] Well-Known Member
    Tommy
    Lexington, SC
    2012 DC SR5 Short
    3'' Lift Eibach Springs 5100's Billies 16x10 Rims 265/75 Generals 20% tint all around
    So I have researched all the threads I could but none seem to be the same problem as mine. They all describe like squeaks and clanking sounds but mine is different. I have a 2012 with less than 10,000 miles on it. I did a Toytec 3'' lift on with the 1.5'' AAL with 5100's in the rear. Hoping sombody can help me out cause this is my 1st Toyota and loving it and this site as been nothing but help.
    PROBLEM= When I go over certain bumps I get this annoying sound that sounds like your shaking a bag of change or dropping washers or somthing. I have checked everything I could think off. Ive checked the washers on the shocks. Ive also checked the U-Bolts and everything. It happened after I installed the AAL cause at 1st I had blocks but did the switch to AAL's which actually lowered the back end a little. It doesnt do it going over your usuall bumps in the highway or Interstate but when Im going down gravel roads or speed bumps I hear it. Any help would be appreciated.
  2. May 12, 2012 at 12:34 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    do you have center caps on your rims? if you do, are they on properly and not fitting on loose?
  3. May 12, 2012 at 12:36 PM
    JayDawg
    JayDawg Christian Pastor. Need prayer,have questions? Ask
    Jay
    Sterling, Co. via San Diego, Ca.
    Tacoma 4x4 Access Cab TRD Off Road Package
    4-PIAA 80 Racing Series Off Road Lights, Randy Ellis Design Light Bar, Bilstein 5100 Shocks, Rear Leaf TSB, Mickey Thompson Classic Lock wheels, fog light mod, more to come...
    When I first saw this thread, I thought it was going to be a post about my wife... :D
    Have you checked to make sure your spare tire is still in place pretty tight? If it works it's way loose, it will make the same noise you are describing.
  4. May 12, 2012 at 12:43 PM
    crushsouls33
    Tommy
    Lexington, SC
    2012 DC SR5 Short
    HAHA at the wife comment... but I'll have to check the spare tire mount but I did zip tie the chain a while back but Ill check the spare mount itself and let you know but thanks for the suggestion.
  5. May 12, 2012 at 5:35 PM
    crushsouls33
    Tommy
    Lexington, SC
    2012 DC SR5 Short
    So I tightened the spare as it was a little loose and me and the wife went out to eat but heard no noise at all. Thanks for the help!
  6. May 12, 2012 at 9:46 PM
    JayDawg
    Jay
    No problem! Now hopefully she doesn't have any rear end noise going on either!:p
