HELP with reverse lights
Discussion in 'Lighting' started by Radred05, Nov 5, 2011.
  1. Nov 5, 2011 at 7:24 PM
    Radred05
    Radred05 [OP] Well-Known Member
    Mitch
    Maryland
    05 Tacoma Sport
    Fog light Mod 5% tint on back 15% up front with eyebrow 35% windshield k&n intake mbrp dual exhaust TRD sport seat covers OBX sport pedals Blacked out grill Painted engine cover Painted hood scoop 3" Toytec lift 1.25" wheel spacers Blacked out tails Smoked Headlights 8K HID Headlights 8K HID Fogs LED third brake light
    Hey guys..i bought a tailgate light bar and it has reverse lights and i need to splice into my reverse lights for them to come on..can anyone tell me what color the REVERSE light wire is on an 05 tacoma?
    Thanks
  2. Nov 5, 2011 at 7:29 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Not sure of the wire color, but pull a tail light out and look at the back. It will be very obvious. You can see which socket is the reverse light bulb, one of the two wires will be common to every light back there (ground). The other is reverse.
  3. Nov 5, 2011 at 8:33 PM
    mr2r6
    mr2r6 Well-Known Member
    Charleston, SC
    16 TRDOR 4X4
    Remove the taillight and its the red wire with white stripe.
  4. Nov 6, 2011 at 2:42 AM
    Radred05
    Mitch
    Maryland
    05 Tacoma Sport
    I read that it was the red wire before so I tried it and it wont light up.
  5. Nov 6, 2011 at 9:53 AM
    Radred05
    Mitch
    Maryland
    05 Tacoma Sport
    Someone help!!
  6. Nov 6, 2011 at 7:26 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Did you ground the tailgate bar? How many wires does it have coming out of it? Does anything else on that bar work? Is it LED? LEDs don't work if you have the power and ground wires backwards.
    A picture of the tailgate light bar you bought and it's wiring connections may help us help you out.
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyewd/06toypdf/ewd/2006/tacoma/h/em01d11.pdf
    Here is the wiring diagram. Should be red wire with white stripe for positive and white wire with black stripe for negative (ground). Both wires should be accessable at the rear of the light socket that holds the stock back up light bulb.
  7. Nov 7, 2011 at 5:34 AM
    Radred05
    Mitch
    Maryland
    05 Tacoma Sport
