Help with stereo install
Discussion in 'Audio & Video' started by Fiend13, May 26, 2015.
  1. May 26, 2015 at 4:15 PM
    Fiend13
    Fiend13 [OP] Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
    I ordered a pioneer avh-1700s alongwith the axxess jbl amp interface and a metra steering wheel control harness. Now that I see it all in person I feel I may be in over my head. I've installed a single din unit years ago in an old vehicle but that's it. Everyone said this was no different. So, my question is, do I wire the factory wires into the amp interface and then the amp interface into the harness that comes with the stereo? Also, the instructions for the steering wheel harness said I need an adapter for it to work when I was told by other members that I wouldn't need it. It's the metra turbowire harness part # 70-8114. Any help would be greatly appreciated. Thanks!
  2. May 26, 2015 at 4:20 PM
    medic2230
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB 2019 TRD PRO 4runner
    Amp interface should go between the truck wiring and the new HU. The one I used in the runner used the preouts from the HU instead of the line outs.
    I never got the steering wheel controls so I can't help you there.
  3. May 26, 2015 at 4:25 PM
    Fiend13
    Chad
    Ok, thanks. Just wanted to make sure I had the interface right. So like I though, stereo harness>interface>factory wiring.
  4. May 26, 2015 at 4:28 PM
    medic2230
    Murph
    Bama! Roll Tide
    Yeah. Does it have the RCA's to hook the new HU to or does it use the speaker wires?
  5. May 26, 2015 at 4:38 PM
    Fiend13
    Chad
    No RCA's. All wiring. The HU has RCA inputs though.
  6. May 26, 2015 at 5:17 PM
    medic2230
    Murph
    Bama! Roll Tide
    Gotcha. The one for the runner used RCA's to interface with the JBL. Don't know if the taco's are the same with needing a digital signal to turn the factory amp on. My (4Runner) adapter switched everything to digital.
  7. May 26, 2015 at 5:23 PM
    Fiend13
    Chad
    Gotcha. The interface I have isn't digital but it has a USB slot for updates if it ever needs it. There is a wire in the harness for powering on the amp.
