Help with the mass air flow sensor.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mostropr, Apr 12, 2015.
  1. Apr 12, 2015 at 2:57 PM
    Mostropr
    Mostropr [OP] Member
    Tacoma 4x4
    Lift kit
    in my 1998 3.4 tacoma, the mass air flow sensor comes welded to a plastic housing, in the 2000 3.4 model, is separate, is screwed the sensor to the housing. it's oviaous there is more airflow in the 2000 unit. Is the same wiring? Can i replace the mass air flow sensor in my 1998 3.4 tacoma (the whole unit) with the one that comes in a 2000 ( the whole unit? 3.4 tacoma? I check all prints for wiring and to me look the same, i think is a plug and play. Any help, is appreciated. Thanx
  2. Apr 15, 2015 at 5:25 PM
    Mostropr
    Tacoma 4x4
    Lift kit
    No body knows?
  3. Apr 15, 2015 at 5:26 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    K so the 98 is one big god damnit, and the 2000 is the small sensor that screws into the tube right?
  4. Apr 15, 2015 at 5:32 PM
    Mostropr
    Tacoma 4x4
    Lift kit
    Yeap? But the 2000 is a wider tube. I hear that if i replace the 1998 with a 2000 maff sensor the whole unit will give me a lean code. Is that right? It has the same amount of pins in the connector and in the prints, is the same thing!
  5. Apr 15, 2015 at 5:34 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I do have a sensor for sale. Check the 1st gen market place for details.
  6. Apr 15, 2015 at 5:35 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    why would u want to change the tube/maf combo? Whats wrong with the original 98 one?
  7. Apr 15, 2015 at 5:38 PM
    koditten
    Kirk
    Central Michigan
    They are stupid expensive. I have no idea why.
  8. Apr 16, 2015 at 7:09 AM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    These will answer your pin out questions. I had to swap the pins when I did the TT supra maf conversion. No biggie, a small flat screw driver will release the pin from the connector and just swap the pin positions. I'm going to ditch the supra maf and convert over to the 2000 style in the near future.
  9. Apr 16, 2015 at 12:28 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    for what reason? my 98 runs just fine:notsure::facepalm:
