Help with tire sizing!
Discussion in 'Wheels & Tires' started by Greyyota12, Feb 9, 2014.
  1. Feb 9, 2014 at 6:04 PM
    Greyyota12
    Greyyota12 [OP] Well-Known Member
    Sean
    Richmond Ky
    12 reg 4x4 auto magnetic grey
    I have a 2012 reg cab tacoma. 100% stock. I have searched on here for the last few hours and cannot seem to find a definite answer to my question. I understand that 265/75/16 is the "biggest" tire I can run without lift and mods. My question then is; can I run a taller more narrow tire without any lift or trimming?
  2. Feb 9, 2014 at 6:16 PM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
  3. Feb 9, 2014 at 6:26 PM
    sch0enne
    sch0enne Well-Known Member
    penticton British Columbia Canada
    03 Tacoma TRD
    bed lights, cobra 19 dx cb radio, flow pro muffler
    I would say no...
  4. Feb 9, 2014 at 6:50 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Even a 265/75-16 can have some rubbing. Mine rubbed the mud flaps before I lifted it.
  5. Feb 9, 2014 at 6:56 PM
    Greyyota12
    Sean
    Richmond Ky
    So what about 235/85/16?
  6. Feb 9, 2014 at 6:57 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Research the 255/85/16 size. I think I've seen a couple trucks with this size on stock wheels without any lift. I ran this size on stock wheels and didn't have any rubbing but I have a 3" lift. The tall and skinny tire on the proper spec. Wheels could fit but possibly a little trimming.
  7. Feb 9, 2014 at 6:59 PM
    Greyyota12
    Sean
    Richmond Ky
    Or 245/85/16?
  8. Feb 9, 2014 at 7:02 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I have been told 265/75/16 is the tallest tire that will fit stock. Otherwise it will rub the fenderwells.
  9. Feb 9, 2014 at 7:05 PM
    Mainmoe02
    Moe
    Austin, Texas
    If you like the 235/85/16 then you'll be fine. It's basically the skinnier brother of the 265/75. If you want a 32 and don't mind the tall/ skinny tire then go 235/85 over 265/75.
  10. Feb 9, 2014 at 7:25 PM
    Greyyota12
    Sean
    Richmond Ky
    I actually like the look of tall and skinny and I am looking to shoe horn in the biggest tires possible with the least amount of modding. The taller the better
  11. Feb 9, 2014 at 8:17 PM
    Greyyota12
    Sean
    Richmond Ky
    Also let's say I get a 2" lift. Then what would be to maximum size I could run with emphasis on the tallness? This is again without trimming.
  12. Feb 9, 2014 at 9:06 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    32.5" . After that you get into removing mudflaps.
  13. Feb 10, 2014 at 8:20 AM
    Mainmoe02
    Moe
    Austin, Texas
    If you get a 2" lift then you'll be good with 255/85's on stock wheels.
    The stock wheel specs are perfect for a tall n skinny tire. You'll have rubbing if the tire gets stuffed in the wheel well but for daily driving you'll be good to go.
    The issue most people have is that when they go with a bigger tire it's usually also wider. Taller and wider on stock or after market wheels is when you get the rubbing issues even just daily driving. The tall and skinny tire has less rubbing because of the width, it's slightly skinnier than the stock 265/70 tires.
  14. Feb 10, 2014 at 9:28 AM
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    I have no lift and I'm running 265/70/17
  15. Feb 10, 2014 at 10:13 AM
    Greyyota12
    Sean
    Richmond Ky
    Thanks for the replies. I'm just trying to work through this but I'm new to it. I won't be doing any hardcore off-roading but I do go off road some. I drive about 400 miles a week almost exclusively interstate. What I'm trying to do is put the minimum into mods on the truck and stuff the biggest tires possible. I will be trading this truck in for a 4dr at some point so I don't want to deck it out too much.
    So now I wonder, do the clearance issues have to do with the front more? If so could I put a 1.4-2" spacer up front and leave the rear and run a larger tire?
  16. Feb 11, 2014 at 7:22 AM
    Mainmoe02
    Moe
    Austin, Texas
    Well with the high mileage weekly driving I wouldn't recommend going big/ heavy tires because it's will bring your mpg's down. If your ok with that then instead of spacers get the 5100 bilstein shocks and set them at the 3rd setting to gain 1.75" of lift. This height in the front will get you close to sitting level, maybe a little nose high. And yes most rubbing issues come from the front. You could leave the rear suspension alone and just lift the front, which is referred to as "leveling the truck".
  17. Feb 11, 2014 at 11:06 AM
    smmarine
    Melbourne FL
    Well he does say it's mostly interstate driving which bigger tires would actually help a little because more weight=more momentum, and there's a slightly lower gear ratio which in turn brings rpm down, and fuel economy up. I went to 31x10.5x15 from 235/75/15(basically a 28.5"), and my economy is about the same city, if not a little better. And that's from street tires to aggressive tread all terrains
  18. Feb 11, 2014 at 4:28 PM
    Greyyota12
    Sean
    Richmond Ky
    I think I am leaning towards a leveling kit to keep it simple. Now I just need to figure out which kit and how big of tires I can go if I just lift front to level it.
  19. Feb 11, 2014 at 7:33 PM
    smmarine
    Melbourne FL
    The best level your gonna find would be some bilstein 5100s with some OME or another reputable brand coils. It's apparently a great off road shock with great on road characteristics, and the height is ajustable. I wish I could get them but They are just a little pricey. I will probably be going with some rough country shocks with extended coil springs, and a very small spacer. 80 bucks for shocks vs $150ish
