Help with traction control on LT truck
Discussion in 'Long Travel Suspension' started by Jyam180p, Dec 8, 2013.
  1. Dec 8, 2013 at 6:38 PM
    Jyam180p
    Jyam180p [OP] Member
    Fort Bragg,CA
    '11 Taco 4X4
    All Pro LT kit, All Pro Expo leafs, u bolt flip kit, Fox 2.5's, Trail Ready bead locks, Owens tool box, Timbren bumps, Mc'Neil 3"x3" fenders,Relentless Fab bumper.
    Hello,
    Last weekend I installed a All pro LT kit on my 2011 tacoma. Once I had it aligned, I drove the windy road home. On my way the traction control was going off around sharp turns around 25mph. The truck was gripping fine and was definitely not being pushed hard at all. Also, on the highway, It was wandering in the turns pretty badly. I re checked the torque on wheel barring and lugs, as well as the steering shafts. All was well. Anybody have any experience with this after installing an LT kit?
  2. Dec 9, 2013 at 4:39 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    You need to do a zero point calibration for the VSC/ABS whenever you do anything at all to the suspension, steering, and alignment.
    Wandering is most likely due to alignment. What's your alignment spec sheet look like? You want as much caster as you can.
  3. Dec 10, 2013 at 8:39 AM
    Jyam180p
    Fort Bragg,CA
    '11 Taco 4X4
    Thanks for the reply!
    I made sure that the shop that did the alignment had a machine rather than a tape measure had job. They put it to factory specs, but since then i've learned that it may need a 3-4 degree caster? Does this sound correct? I had planned on having the alignment done again after the springs break in and I adjust the height accordingly. Hopefully with some help I can get the #s for the correct specs. After I have that dialed in, I'll have the VSC/ABS calibrated. (Thanks for the info on that!) Can any shop calibrate this or is it something I need to deal with at a dealer?
  4. Dec 10, 2013 at 8:44 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  5. Dec 10, 2013 at 9:48 AM
    Jyam180p
    Fort Bragg,CA
    '11 Taco 4X4
    Thanks OZ-T, much appreciated.
  6. Dec 17, 2013 at 2:54 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Recalibrate is super easy and you should not wait. Requires the manual procedure and a couple of paperclips. The truck needs to be on flat ground with the wheels pointed straight ahead.
    PK
