Help with ways to carry my bikes (bicycle )
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mark5112, Jul 22, 2016.
  1. Oct 15, 2016 at 8:37 AM
    #121
    DwightKSchrute
    DwightKSchrute Well-Known Member
    2017 Magnetic Gray Tacoma TRD Off Road 4x4
    @dman100 I'm getting the hard tonneau cover and I would rather put the bike in the back and close/lock everything up. Especially helpful in florida where there is a lot of salt in the air that could potentially corrode bike parts. I am hoping mine fits to I can shut the tailgate and cover securely. Probably not an ideal set up for camping, when I need the bed for other equipment. At this time, I'll probably explore these rocky mounts and remove my cover. Would be cool if the mount could be installed on the tonneau cover but that would affect the way it folds up.
  2. Oct 15, 2016 at 4:49 PM
    #122
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Honestly, when I carried my friend's Niner lying down, I don't recall if it stuck above the bed rails. So try before you buy. I actually took my bikes to the dealer to make sure they would fit standing up with front wheels removed, and tailgate shut, before I bought it. The sales guy was very patient.
  3. Oct 15, 2016 at 5:27 PM
    #123
    sml2727
    sml2727 Well-Known Member
    I use a Swagman xtc2. its cheap and requires no pulling the front tire off. It even accepts my mid fat tires for my hightower, they do make bigger rings for fatbikes
  4. Oct 15, 2016 at 6:55 PM
    #124
    DwightKSchrute
    I just picked up my TRD off road and threw my bike in the back and it fits with wheel off and tonneau shut. :bananadance:
    dman100 likes this.
  5. Oct 15, 2016 at 7:17 PM
    #125
    HikerTrash
    HikerTrash Member
    Fort Worth, TX
    2017 Blue CM Tundra 4x4 TSS Off Road
    I used a hitch mounted platform and just added wheel guides. Worked like a charm...
  6. Oct 15, 2016 at 7:36 PM
    #126
    TALLNDIRTY
    TALLNDIRTY Active Member
    Winnipeg Manitoba
    2015 Tacoma Access cab SR5 4cyl 5spd 4x4
    I have used this pvc pipe bike rack going on two years....can hold 3 bikes just as long as the middle one is a medium frame. Materials cost $140 and I have had zero issues. Found the plans and specifications on the net.Screenshot_2016-04-02-15-56-23.jpg
    DwightKSchrute likes this.
  7. Oct 15, 2016 at 7:39 PM
    #127
    TALLNDIRTY
    Winnipeg Manitoba
  8. Oct 16, 2016 at 1:56 PM
    #128
    DwightKSchrute
    Finally got my hands on my new truck and took the bike out. Test fit the 19.5" (XL) frame into the bed. It will work with handlebars first but not back tire first. Tonneau will shut and lock, and bike did not roll around. I'm also getting a bed mat to give it a little more traction just in case.
  9. Dec 11, 2016 at 4:52 PM
    #129
    AshleyasF*ck
    AshleyasF*ck New Member
    How did you mount it without drilling?
  10. Jan 16, 2017 at 6:40 PM
    #130
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    Anyone have experience with the rocky mounts and long trips? I go home once a month and it's 1k miles round trip and I'm not baller enough to have two bikes.
  11. Jan 16, 2017 at 6:51 PM
    #131
    AustinNative
    AustinNative Swollen Member
    ATX
    2017 MGM TRD Sport DCSB
    Maxtrac spindles OME 885s Bilstein 5100s all around (adjustable front/extended length rears) Maxtrac rear blocks Headstrong Taco lean spacer OME CBD SS brake lines InsaneFab CMC 18x12 Fuel Hostage 35x12.50 Maxxis AT 1.25" Spidertrax spacers in the rear Llumar Ceramic Tint (5% Rears & Back / 18% Fronts / 50% Windshield) Toyota Tri-Fold bed cover and OEM bed mat Triple Black Clazzio seat covers WeatherTech laser fit or whatever the fuck they call em Probably other stuff...
    I made a 3 bike version of this out of about $15 in PVC when I had my 2nd gen. I put the front wheel in it, and turn my back wheels to the corner and my tailgate closes. Medium size frame 27.5 tires. I'm guessing it wouldn't work with a 29r in a 5' bed. I thought about using the same basic principle but building it for 2 bikes to fit facing corner to corner but I'm busy dicking around on a new PVC contraption for storage of 2 kayaks and 2 upright or hanging bikes in the garage. PVC is like Lincoln Logs for adults.
    257598d1379866330t-bed-bike-racks-image-_456b732e815d3cc8235cc29a485e50b6dbe9c187.jpg
    TALLNDIRTY likes this.
  12. Jan 16, 2017 at 7:12 PM
    #132
    JJ TACO
    JJ TACO Well-Known Member
    16 TRD OR DCSB MT QUICKSAND
    Rocky mounts are great. I never had a problem with mine on road trips.
  13. Jan 16, 2017 at 8:39 PM
    #133
    slowboater
    slowboater Well-Known Member
    Contact Cody at Recon Racks.
    http://recon-racks.com/
    The best rack I've ever seen. I bought one - and the stand for in my garage. I can - no exaggeration - unload 4 bikes off the rack in my garage, put the rack on my truck, and reload 4 bikes in well under 10 minutes.
    Cody is a stand up guy and recently quit his 'real job' to make racks full time. They're not cheap but by the time you dick around trying to do it yourself - you'd probably spend the same amount of $$ and have a product not nearly as nice.
    Tell him Joel from Vancouver sent you.
  14. Jan 16, 2017 at 8:41 PM
    #134
    slowboater
    BTW - Cody is an avid offroader. He used to drive a Taco but I think he moved up to a full sized recently. He takes his bikes out to the shit - so built a rack to handle punishment. I've got some pix to upload I suppose but you can see Cody's pix on his website.
  15. Jan 31, 2017 at 8:57 AM
    #135
    Effin Genius
    Effin Genius Well-Known Member
    Fort Lauderdale, FL
    '05 PreRunner DCSB V6
    Wait for it...
    I have Rocky mounts, hitch carrier & tailgate pad as options for carrying but I still haven't come up with a solid way of carrying 1 of my bikes (full squish or road bike) IN the bed WITH BOTH wheels on & tailgate closed. Both bikes will fit diagonal & gate closed but I need to make a wheel chock for front wheel & secure method for rear wheel. Hoping someone chimes in with a corner chock they've made. Hate hooking ratchet straps on bikes that have a comma in the price. Capture+_2017-01-31-11-51-20.jpg Capture+_2017-01-31-11-50-47.jpg
  16. Jan 31, 2017 at 10:28 AM
    #136
    NY Taco
    NY Taco Well-Known Member
    Rochester, New York
    2017 Inferno Sport DCLB
    Leer 180 Cap, Beat Sonic Navi By-Pass
    I'm building a sliding mount for our tandem.
    lowprofile likes this.
  17. Jan 31, 2017 at 11:12 AM
    #137
    Harbormaster
    Harbormaster Active Member
    2016 Tacoma TRD Pro DCLB
    2 Yakima viper racks on my roof. Very low profile. Just need to remove the front wheels.
  18. Jan 31, 2017 at 11:34 AM
    #138
    drwx
    drwx Well-Known Member
    M'boro, TN
    2017 DCSB TRD Offroad 4x4 BBP
    materials cost $140 holy crap... is that at typo?
  19. Jan 31, 2017 at 11:41 AM
    #139
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    This is my method as well and it works like a champ. I don't see a reason to ever change. I have a some rails for a camper shell that I may install on my 2x12 so that I have the ability to slide the fork mounts around or add an additional bike. This has been working really well for me. When it's just me, I just throw it in there without mounting it up and it fits fine.
  20. Jan 31, 2017 at 2:03 PM
    #140
    tspencerVA
    tspencerVA Well-Known Member
    Roanoke, VA
    2017 TRD OR DCSB
    TRD Pro Grill, ARE CX HD shell, step bars, Wet Okole, Husky Liners
    Nice rack!
    Have input over on another thread on TW about tailgate clearance and I am 90% sold on the 1-UP. Only thing I need to push me over the edge is a clean picture showing a 3rd Gen with tailgate full lowered and NOT hitting the 1-UP rack at all.
    https://www.tacomaworld.com/threads...h-mount-bike-rack.438318/page-2#post-13756655
    Ideal would be a rack that allows you to sit on the tailgate, fully lowered, bikes in rack and not have to remove the bike closest to the vehicle....not sure if that is even possible
    Anyone have a pic of the 3rd gen tailgate clearance with 1-UP? (OR another rack aside from North Shore that allows my fatness to sit on tailgate with rack on)
