Help with wheel bearing!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xTACOMAx, Nov 15, 2015.
  1. Nov 15, 2015 at 10:45 AM
    xTACOMAx
    xTACOMAx [OP] Well-Known Member
    07 prerunner TSS
    Rough Country 3 inch lift, Aries bull bar, Spider headlights
    Hey guys/gals I'm needing to replace a bad wheel bearing on the front left I have a 2007 2wd Tacoma image.jpgimage.jpg and here's the wheel bearing assembly I bought, well the other part that has the studs for your lug nuts does that have to be press in with a pressing machine or can it be installed by hand?
  2. Nov 15, 2015 at 10:48 AM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
  3. Nov 15, 2015 at 10:56 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    Yea you'll need them pressed with a machine
  4. Nov 15, 2015 at 11:02 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  5. Nov 15, 2015 at 11:34 AM
    xTACOMAx
    07 prerunner TSS
    Ok thanks guys, I was pretty sure it had to be press in but I was just checking before I do replace it
  6. Nov 15, 2015 at 1:16 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Prerunner requires a special socket for the nut too.
  7. Nov 15, 2015 at 1:20 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I changed mine without a press. Just used a small sledge and a block of wood, but I'm a professional hillbilly engineer.
  8. Nov 15, 2015 at 1:37 PM
    Scrapla
    Scrapla Rebel Without a Clue
    South Florida
    2007 Tacoma PreRunner 4.0 V6
    1.5" lift, ARB bumper
    How are the bearings and assemblies made by MOOG, any good any issues?
  9. Nov 15, 2015 at 2:24 PM
    Scrapla
    South Florida
  10. Nov 15, 2015 at 2:28 PM
    Scrapla
    South Florida
  11. Nov 15, 2015 at 5:38 PM
    Scrapla
    South Florida
    Looks like Bill has the best deal thanks for sharing.
    DoorDing likes this.
  12. Nov 15, 2015 at 6:08 PM
    BamaToy1997
    Bill
    Navarre, FL
    Thanks for all of the kind words. I do feel I have a superior quality part and customer service. That part linked above is just the bearing assembly. It does NOT include the hub, which is the majority of the work on these.
  13. Nov 18, 2015 at 9:11 AM
    Scrapla
    South Florida
    I just ordered my 4x2 bearing and also located in Florida.
  14. Sep 30, 2017 at 6:02 PM
    MrZoggs
    MrZoggs Ainokea
    Zach
    Alaska
    13' DCLB Sport
    Some Stuff...
    Thread revival:
    Okay, so i replaced my passenger front wheel bearing/hub with a complete assembly.. the bolt in kind with no pressing required.
    I swapped out the pieces, greased everything sparingly [light coat across everything] and torqued all hardware to manufactures spec.
    The problem: i drove it about 300 ft from the house, i live on a gravel road. And have some serious creaks and groans going on. So much so i was afraid i hadnt installed something right and took it back to the garage. *the dust cover isnt on the hub assembly as i am going to replace it, but thats it.
    I had engaged 4wd and left the drivers tire on the ground when i swapped the assembly. Sounds occur with and w.o 4wd on. I didnt do much checking of the splines when i installed, as i figured if it slid and bolted on i was lined up..
    Any ideas???
  15. Sep 30, 2017 at 6:21 PM
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
    Make sure you didn't slightly bend the brake dust shield, it maybe rubbing on the disc.
  16. Sep 30, 2017 at 6:23 PM
    MrZoggs
    MrZoggs Ainokea
    Zach
    Alaska
    13' DCLB Sport
    Some Stuff...
    I was sure to check that. Thanks tho..
    It sounds like a louder continuous cycling of some squeaky ass suspension.
    brny67 likes this.
