help with wire id
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95FourBanga, Apr 19, 2012.
  1. Apr 19, 2012 at 4:55 PM
    95FourBanga
    95FourBanga [OP] New Member
    Louisiana
    95 4cyl 4x4 DLX
    I have done exhaustive searches on this and other forums and cant seem to come up with a solid conclusion. What I'm trying to find out is the identification of the four wires behind the dash next to the ignition that were for the stock clock (which mine did not come with). I'm adding an aftermarket tach and was wondering if any or all of those wires would work for the switched 12v, ground, or illumination wires. Any help is appreciated.
    Edit: I have a 95 4cyl 4x4 5spd, which im told was one of the years where the wiring was different from most of the others.
