HELP!! Won’t beep or light up when locking.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lefty9206, Nov 21, 2020.
  1. Nov 21, 2020 at 11:14 PM
    lefty9206
    lefty9206 [OP] Well-Known Member
    Jarrod
    2021 gray TRD off road
    None yet
    I just noticed that when I unlock my car it flashes and beeps but when I lock the car it does not beep or flash like when I bought the car. it used to flash and beep when I would lock/unlock but it stopped when I lock it now and I would like to have it flash and beep for both. Please help.
  2. Nov 21, 2020 at 11:32 PM
    lefty9206
    Jarrod
    None yet
    Just to add more information. I added sound deadening on the doors today and put everything back together. Since it’s dark and I can’t work on it right now my guess is that I didn’t put the door latch and lock back together properly and so the vehicle doesn’t think it’s being locked all the way. I will update tomorrow once I have successfully put it back together and the latch and lock work smoothly
  3. Nov 21, 2020 at 11:33 PM
    TacoTim85
    TacoTim85 Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    One of your doors is ajar.
    Edit: Or the truck thinks it is.
  4. Nov 21, 2020 at 11:35 PM
    lefty9206
    Jarrod
    None yet
    I thought so too. It’s weird though because it’s not making the obnoxious beep like if I tried to lock it with a door open.
  5. Nov 21, 2020 at 11:38 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    I could be wrong but you might have accidentally hit a sequence on your keypad to bypass the beep/ light flash. Check the owners manual. I believe there is a way to shut all of that off or bring it back pretty easily.
  6. Nov 21, 2020 at 11:41 PM
    Texas T
    TX
    '14 T Force
  7. Nov 21, 2020 at 11:44 PM
    lefty9206
    Jarrod
    None yet
    I just went outside and checked the door in question and it is not locking when the other doors lock and the handle is sticky. I will take it back apart in the morning and make sure everything is smooth again. If that doesn’t work I will follow the videos steps
  8. Nov 21, 2020 at 11:45 PM
    Texas T
    TX
    '14 T Force
    CygnusX191 likes this.
  9. Nov 22, 2020 at 12:03 AM
    lefty9206
    Jarrod
    None yet
    Thank you for your help. I’ll update in the morning.
    Texas T likes this.
  10. Nov 22, 2020 at 1:12 PM
    lefty9206
    Jarrod
    None yet
    Update!! It was in fact the door linkage not being properly set causing the latch to not engage I.e. car wouldn’t fully lock unlock
  11. Nov 22, 2020 at 1:30 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Lucky it didn't come detached after you closed the door!
    Chew likes this.
  12. Nov 22, 2020 at 2:13 PM
    lefty9206
    Jarrod
    None yet
    Yeah very true. It was a little hard to open but it worked out and now everything works.
    wilcam47 and tcjacado like this.
  13. Nov 23, 2020 at 5:30 AM
    lefty9206
    Jarrod
    None yet
    Thanks to anyone who gave advice or shared links. This forum is great.
    wilcam47 likes this.
  14. Aug 3, 2021 at 7:32 AM
    PeteK
    PeteK Well-Known Member
    Brockton, MA
    2017 Cement Truck
    Thanks for this thread. I've got the same issue and will check this out. Just a couple miles past warranty, so perhaps the dealer will look at in good grace.
  15. Apr 1, 2024 at 5:42 AM
    RhodeIsland4bang
    RhodeIsland4bang Back seats are for freeloaders!
    Rhode Island, USA
    2011 DCSB SR5 6MT
    Count of one four legged freeloader
    Hey just adding to this thread, my 2011 the driver rear door started not fully locking/unlocking with the fob or lock button inside every time a while back, then just not locking but it would still unlock sometimes, now it does not actuate at all with the fob/button. Now in a matter of a few days the beeps/drl flash with the fob became intermittent then stopped entirely only when locking, still works on unlock. Thanks to this thread I am going to start with the assumption that they are related! I’ll try to update when sorted or if I can’t figure it out
